GOTO main or RETURN - Question
Results 1 to 6 of 6
    Default GOTO main or RETURN - Question
    Here is the code for a small program I am trying. Trying to figure out when I replace "GOTO main" with "RETURN" the program only executes one of the items and nothing else happens. If I have "GOTO main" everything works but I really want it to return and continue where it left off instead of always going back to the top of "main" all the time.
    Hopefully I described that ok. Appreciate any help.
    main
    if switch1 = 1 then servocenter
    if switch1 = 0 then low led1
    if switch2 = 1 then servoright
    if switch2 = 0 then low led2
    if switch3 = 1 then servoleft
    if switch3 = 0 then low led3
    if switch4 = 1 then high led4
    if switch4 = 0 then low led4
    servocenter:
    serout lcd1, t9600, [$fe,1," center"]
    high led1
    pulsout servo1, 150
    pause 200
    servoright:
    serout lcd1, t9600, [$fe,1," right"]
    high led2
    pulsout servo1, 100
    pause 200
    servoleft:
    serout lcd1, t9600, [$fe,1," left"]
    high led3
    pulsout servo1, 200
    pause 200
    Dec 2005
    I'm a rookie, but I think using subs will work like this. Subs have to be after the "end" statement.
      main
    if switch1 = 1 then GoSub servocenter
    if switch2 = 1 then GoSub servoright
    if switch3 = 1 then GoSubservoleft
    servocenter:
    high led1
    pulsout servo1, 150
    pause 200
    servoright:
    high led2
    pulsout servo1, 100
    pause 200
    servoleft:
    high led3
    pulsout servo1, 200
    pause 200
    OR, you could move each of the items below each if statement.
      main
    if switch1 = 1 then GoSub 'servocenter
    high led1
    pulsout servo1, 150
    pause 200
    if switch2 = 1 then GoSub 'servoright
    high led2
    pulsout servo1, 100
    pause 200
    if switch3 = 1 then GoSub 'servoleft
    high led3
    pulsout servo1, 200
    pause 200
    Wink
    Having everything within the IF statements work fine. I am trying to get a good handle on subs.
    The return after the "END" did not work. THanks for the input it was worth a try. I am sure it is something simple I am missing. Just unsure what it maybe.
    Keith
    sinoteq's Avatar
    sinoteq Guest
    Default Gosub return
    You may use the GOSUB command when you want to jump to a SUB and then in an easy way get back to where you jumped from. The SUB you jump to can be anywhere in your program (before or after MAIN) as long as it has a unique name JUMPHERE: and the sub ends with a RETURN. Please remember PICs has a limited stack and can only make a few (depends on PIC version) nested GOSUBS before the first jump becomes invalid because you do a stack overflow. Same thing if you try a RETURN before you have made a GOSUB, that will give a stack underflow and will probably hang your program.
    Thanks sinoteq - using the GOSUB command worked perfectly and it returned just like I wanted. Greatly appreciate it.
    Well, you can only use RETURN when you have jumped to a routine with GOSUB - NOT when you jump to it with GOTO.
    Try:
    If Switch1 = 1 Then
      Gosub ServoCenter
    Else
      Low LED1
    EndIf
    'And so on...
    Goto Main
    ServoCenter:
    'Code here
    'And so on....
    Edit: Oh well, was a bit late there I see....
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 06:28
  2. Making a menu
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 12th November 2008, 19:54
  3. Replies: 14
    Last Post: - 26th September 2007, 05:41
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 20:10
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 5th May 2005, 23:29
