Help me with interupt
Results 1 to 4 of 4
    Feb 2007
    Malaysia
    Default Help me with interupt
    I have success to make an LCD Clock and able to do interrupt for an Led to on for certain period. I am trying to do something like moving a servo let say for every one hour. How do I implement the interrupt.
    Please show me some example as I am totally newbie.
    Also to what value I have to change the Option_Reg to use with 20mhz OSC. Now I'm using pause 667 to make the time almost accurate.
    Here's my code:
    @ DEVICE pic16F627a, HS_OSC ' System Clock Options check
    @ DEVICE pic16F627a, LVP_OFF ' Low-Voltage Programming
    DEFINE OSC 20 ' define osc if not using @ device INTRC_OSC_NOCLKOUT
    BAUD con 16784 ' 2400 Baud, inverted, NoParity: conservative for testing
    Ticks VAR byte 'Tick count (61 ticks = 1 sec)
    Hour VAR byte ' Hour variable
    Minute VAR byte ' Minute variable
    Second VAR byte ' Second variable
    Disp VAR byte ' Disp = 1 to update display
    Delay VAR byte ' Used to Debounce button
    TRISB = %00000011 ' PORTB all outputs
    PortB.4 = 0
    Led var PortB.2
    PinOut VAR PORTB.4 ' Tx on RB4
    Hrs var PORTB.0
    Mins var PORTB.1
    PAUSE 1000 ' Wait 0.5sec for LCD to initialize
    ' Initialize timer interrupt. The prescaler is set to 64 and the
    ' TMR0 is left to run from 0 to 255. With a clock frequency of 4MHz,
    ' The timer interrupt is generated at every 256 * 64 = 16.384ms.
    '/ Inside the ISR, variable ticks is incremented by 1. When Ticks = 61
    'then time for a timer interrupt is: 61*16.384 = 999.424ms and variable
    ' Second is then updated. i.e. Second is updated nearly every second.
    OPTION_REG = $05 ' Set prescaler = 64
    ON INTERRUPT GOTO ISR ' ISR routine
    INTCON = $A0 ' Enable TMR0 interrupt and global interrupts
    SEROUT2 PinOut,BAUD,[27,"1"] 'Clear Lcd
    ' Beginning of MAIN program loop
    Hour = 0
    Minute = 0
    Second = 0
    Ticks = 0
    LOOP:
    ' Check Hour button and if pressed increment variable Hour
    if (Minute = 0) And (Second = 10) then
    ' gosub light
    high Led
    gosub Debounce
    if (Minute = 1) And (Second = 0) then
    ' gosub light
    high Led
    gosub Debounce
    IF Hrs = 0 THEN
    Hour = Hour + 1
    IF Hour = 24 THEN Hour = 0
    Gosub Debounce
    'Check Minute button and
    IF Mins = 0 THEN
    Minute = Minute + 1
    high Led
    IF Minute = 60 THEN Minute = 0
    Gosub Debounce
    ' Display update section. The display is updated when variable
    ' Disp is 1. This variable is set to 1 inside the ISR when the
    ' seconds changes. The cursor is set to home position and the
    ' time is displayed on the LCD
    IF Disp = 1 THEN
    serout2 PinOut, BAUD,[ 12," The Time Is " ]
    serout2 PinOut, BAUD,[12," H:",DEC2 Hour," M:",DEC2 Minute," S:",dec2 Second]
    pause 667 ' if use 20mhz crystal
    Disp = 0
    GOTO LOOP
    ' This subroutine Debounces the buttons. Also, a delay is introduced when
    ' a button is pressed so that the variable attached to the button (Hour or Second)
    ' can be incremented after a small delay.
    Debounce:
    FOR Delay = 1 To 200
    Pause 1 ' Delay 1ms inside a loop. This way,
    NEXT Delay ' timer interrupts are not stopped
    Disp = 1 ' Set display flag to 1
    ' This is the Timer interrupt Service Routine. The program jumps to this code
    ' whenever the timer overflows from 255 to 0. i.e. every 256 count. The prescaler
    ' is set to 64 and the clock frequency is 4MHz. i.e. the basic instruction cycle
    ' time is 1 microsecond. Thus, timer interrupts occur at every 64*256 = 16.384ms.
    ' Variable Ticks is incremented by 1 each time a timer interrupt occurs. When Ticks
    ' is equal to 61, then one second has elapsed (16.384*61 = 999.424ms) and then
    ' variable Second is incremented by 1. When Second is 60, variable Minute is
    ' incremented by 1. When Minute is 60, variable Hour is incremented by 1.
    ' Timer TMR0 interrupts are re-enabled just before the program exits this routine.
    DISABLE
    ISR:
    Ticks = Ticks + 1
    IF Ticks < 61 THEN NoUpdate
    ' 1 second has elapsed, now update seconds and if necessary minutes and hours.
    Ticks = 0
    Second = Second + 1 'Update second
    if(Minute = 0) And (Second => 30) then
    low Led
    if(Minute = 1) And (Second => 30) then
    low Led
    IF Second = 60 THEN
    Second = 0
    Minute = Minute + 1 ' Update Minute
    IF Minute = 60 THEN
    Minute = 0
    Hour = Hour + 1 ' Update Hour
    IF Hour = 24 THEN
    Hour = 0
    Disp = 1 ' Set to update display
    ' End of time update
    NoUpdate:
    INTCON.2 = 0 ' Re-enable TMR0 interrupts
    Resume
    ENABLE ' Re-enable interrupts
    END 'End of program
    Sorry for the long listing.
    Feb 2007
    Malaysia
    Hi all,
    While waiting for somebody to reply I have done few experiment with the code but nothing come close to what I need.
    I need my small robot to move around every 10 minutes and sleep after 3 minutes. Can somebody show me how? I can do with the High and Low for Led but not the servo.
    I dont need the complete code. Just let me know how or where to put the code. Although I have some experience with Basic Stamp I have never play with interrupt before.
    Really appreciate if somebody could give me some light.
    thanks & regards.
    Have a look at Darrell's Instant Interrupt routines, you'll find them on his web-site. Then look specifically at the Timer template that he has there. That should get you started.
    Feb 2007
    Malaysia
    Thanks Henrik. You light up my life.
  1. Replies: 4
    Last Post: - 17th December 2009, 00:29
  2. Help! My 'interupt', erhm ...only interupts the one time?!!!
    Last Post: - 2nd November 2009, 12:49
  3. on interupt with pic 16F619
    Last Post: - 29th March 2008, 17:39
  4. Any Simple ASM interupt code examples out there?
    By George in forum mel PIC BASIC Pro
    Last Post: - 28th March 2007, 04:19
  5. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 00:38
