Write to eeprom
Results 1 to 7 of 7
Thread: Write to eeprom
    PBP has a way of looking at the EEPROM addresses as simple numbers.
    So you can
    WRITE 0
    WRITE 1
    WRITE 2
    all are different places in the EEPROM.
    Want to automatically increment?
    X = X + 1
    WRITE X
    Sep 2005
    Campbell, CA
    I think you may be asking how you write to a different address - even across power cycles.
    If that is the case, write to the EEPROM, and then write the last-used address + 1 to the two highest EEPROM addresses (1022 and 1023 on many devices)
    Before you write to EEPROM, read those two addresses to get the next address to write to, and when you are done, write the last address + 1 to 1022 and 1023 again.
    Charles Linquist
    X = X + 1
    WRITE X
    This works for sure, but if the PIC shuts down it will overwrite the EEPROM from the beginning.
    Quote Originally Posted by Charles Linquis View Post
    Could you please tell me more about this?
    Sep 2005
    Campbell, CA
    I don't know what I didn't already explain.
    But..
    When you program your device, make certain that you erase the EEPROM to all '0's'.
    Now if you want to write to the EEPROM
    READ 1023,WriteStart.LowByte
    READ 1024,WriteStart.HighByte
    Now write your data -
    WRITE WriteStart,(your data goes here)
    WriteStart = WriteStart + 1
    Now write back the value of WriteStart so it can be the starting address
    the next time you WRITE. Every time you issue a WRITE, you need to
    increment WriteStart. When you are done writing (or even after every WRITE
    if you really want to protect against power failure).
    WRITE 1023,WriteStart.LowByte
    WRITE 1024,WriteStart.HighByte
    Charles Linquist
    Charles: I do understand now, thanks!!
    Sep 2005
    Campbell, CA
    Just don't make the mistake I just did. The highest address on a 1024 byte EEPROM is 1023!
    Charles Linquist
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
