Weird SPI interface: VIH to VIHH for CS?
Results 1 to 10 of 10
    Huntsville, AL
    Ah, I figured out the VIHH thing. It's Vdd + some delta-V used in order to use their "wiperlock" technology. You can only activate it if CS exceeds Vdd.
    Regardless, I still can't adjust the resistance of the chip. I'm using the following code with a 16F628:
    cmcon=7
    define osc 8
    res var byte
    CS var porta.2 'CS
    CLK var porta.3 'CLK
    SI var porta.4 'SI
    LED var porta.1 'LED
    high CS
    high LED
    low LED
    high LED
    repeatit:
    res=24
    low CS
    shiftout SI,CLK,1,[%00000000\8,res\8]
    high CS
    low CS
    shiftout SI,CLK,1,[%00010000\8,res\8]
    high CS
    pause 200
    res=res+128
    goto repeatit
    I have a 10k pullup resistor on SI, yet no change in resistance.
    Any advice or help is appreciated!
    move res=24 before your repeatit label may help
    Maybe not a bad idea to set the clock LOW at the top of your code.
    Huntsville, AL
    Good catch. But even with the res=24 inside the loop, I'm still reading 100k across the wipers and the A terminals, and low resistance across the wipers and the B terminals. I slowed down the clock with a "define shift_pauseus 100", took the res=24 outside the loop, but still can't see any changes in resistance. Here's my adjusted code:
    cmcon=7
    define osc 8
    res var byte
    CS var porta.2 'CS
    SI var porta.4 'SI
    high CS
    high LED
    low LED
    high LED
    res=24
    repeatit:
    low CS
    high CS
    pause 10
    low CS
    high CS
    res=res+32
    goto repeatit
    I also have 10k resistors between the MCP4261 pins and the 16F628A pins, but that shouldn't affect anything.
    WP and SHDN can be left floating, right? Am I correctly formatting the command byte? Aren't the memory locations %0000 and %0001 the correct ones to address?
    Thanks for the help!
    I wouldn't leave a pin floating myself, mainly SHDN. On the other hand, by their specs, they says there's a "Smart Pull-Up" inside... how smart it is... who knows
    Your code seems to be ok to me, but you still haven't added the LOW CS in there... not sur if this could help though...
    PS: Make sure your DEFINEs are all in UPPERCASE.
    Do you have a PICKIT 2? in this case you could monitor what happen on CS/CLK/SDI and SDO
    Do you have a complete schematic of your thing?
    EDIT: Try this one
            define OSC 8
            cmcon=7
            res var byte
            Command var WORD
            CS var porta.2 'CS
            SI var porta.4 'SI
            high CS
            LOW CLK
            high LED
            low LED
            high LED
            res=24
    repeatit:
            command.highbyte=0 ' Volatile Wiper 0
            comand.lowbyte=res
            low CS
            shiftout SI,CLK,1,[command\16]
            high CS
            pause 10
            Command.HighByte=%00010000  ' Volatile Wiper 1
            low CS
            shiftout SI,CLK,1,[Command\16]
            high CS
            res=res+32
            goto repeatit
    Huntsville, AL
    It still wasn't working... until I changed out the 10k resistors with 500 ohms. Apparently the 10k were too high. Maybe there's an internal pull up or down that was low enough to prevent the pin from reaching the required voltage threshold.
    What pins should I be worried about protecting anyway? CS, SI, SO, CLK, etc?
    Are you saying that your 10K resistor where in serie between the PIC and the MCP chip?
    If so, you just don't need any, connect them directly. The only concern you may have, is the open-collector ones. In this case 10K or lower are nice between 5V and your pin.
    Huntsville, AL
    Yeah, I usually put them on to prevent burning out a pin on accident. What pins are considered "open-collector"? Do CS, CLK, and SI typically have internal resistors that limit current flow? What about SO?
    Thanks!
  1. Master SPI interface to LCD/OLED??
    Last Post: - 19th September 2009, 23:44
  2. need help for APR6008 SPI interface
    By vu2iia in forum mel PIC BASIC Pro
    Last Post: - 30th June 2009, 03:19
  3. 16-bit SPI problem
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 15:42
  4. Help with MicroMag3 SPI interface to PIC
    By kaan in forum mel PIC BASIC Pro
    Last Post: - 31st May 2006, 23:20
  5. Serial Peripheral Interface (SPI)
    By O2_Guy in forum Serial
    Last Post: - 22nd March 2006, 20:01
