Well higher impedance voltage divider may help or screw your reading depending at least of your instrument input impedance.
However higher impedance of your voltage divider, the less you alter the RC filter.
Personally, i would avoid a too high impedance to the instrument, maybe refine the whole design with a buffer in between.
Some instruments also have their own low pass filter at the input, so I would compare a DVM reading with. Not as this sure that you really need to go crazy in your PWM filtering. First order might work as well.
