How to use MPASM 'INC' files?
Results 1 to 10 of 10
    Dec 2008
    Los Angeles, CA
    When in include this line:
    @ INCLUDE "P18F67J60.INC"
    I get
    "Message[310] c:\path...\p18f67j60.inc 3210: Superseding current RAM and RAM map"
    What does this mean? (MPASM did report that the assembly was successful, however)
    Do not include that line. The compiler has already taken care of all that.
    Dec 2008
    Los Angeles, CA
    Yeah, that was slowly dawning on me. All I'm trying to do is set the oscillator to EC (external oscillator). So, after looking at the .inc file, it says at the bottom that there's a bunch of settings that are valid, including FOSC=EC. (They all have ; in front
    so I include this line in my PBP program...
    @ CONFIG FOSC=EC
    and I get the following:
    Error[176] c:\path...\test.asm 75: CONFIG Directive Error: (multiple definitions found for setting "FOSC")
    I have NOT removed any ; from in front of the settings (actually, I tried it both ways), so don't know what's wrong.
    This thread will help
    In the PBP *.inc file you will need to comment out the config lines to set the configs in code space.
    The default setting in the PBP *.inc file is for HS. An external OSC. So you really do not have to do anything.
    The file you are looking at with ";" in front of each line is the MPASM inc file. You DO NOT want to change anything here. Just look at it to see the options.
    I will bet HS is the setting you want. That is for an external resonator.
    EC will give a clock out function.
    Dec 2008
    Los Angeles, CA
    Oh my gosh, you're right!!
    I really AM confused! I see that the settings are actually set in the c:\pbp\18F67J60.INC file. When I want to change settings, should I just edit this c:\pbp\18F67J60.INC file manually, or put @ CONFIG lines in my source file??
    Then what is the purpose of the c:\mpasm\mpasm suite\P18f67J60.INC file? Just to show what options are available?
    CONFUSED! Hey , that means thing are going well
    It is kind of a personal preference as to where you set the configs.
    If you do not plan on changing them often then the inc file might be the way to go. If you like playing with things or have different applications using the same chip then setting the confis in your code might be better.
    If you do set them in the code you will not have to remember how you have things setup when you do an upgrade or something like that.
    The MPASM *.inc is also used by the compiler...or is it the assembler?
    If you read through it you will see all of the lines that are not commented. Those are used for something somewhere.
  1. 12F675 MCLR directive MPASM
    By OLDSCHOOL in forum mel PIC BASIC Pro
    Last Post: - 4th May 2008, 01:29
  2. MPASM 18F4550 getting started
    Last Post: - 4th September 2007, 23:59
  3. 18F8722 and MPASM confusion!
    By Jackson in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2006, 01:24
  4. Replies: 2
    Last Post: - 13th December 2005, 00:11
  5. Converting to MPASM
    Last Post: - 4th November 2005, 01:35
