Messure the RPM through the bord-voltage
Results 1 to 4 of 4
Threaded View
  1. #4
    Yup, and depending of the Alternator, some already have an output on... some ford and GM has it in the past when I installed Remote-Starter.... a bit why I also suggest the Hall-Effect sensor... I used a load of the following in the past
    http://shopping.canoe.ca/shop/produc...IDetailedSpecs
    I think they use Hall-Effect or a simple microphone...
    Pedro, look at DEI, they do a module like you want... but still I wouldn't use it Myself.
    http://carjamz.com/zen/index.php?mai...oducts_id=3722
    Sure enough it's easy to do, what i figure out is to use an Voltage comparator (and/or op-amp). You use a capacitor to remove the DC signal from the 12V line, then you should have only the remaining spikes, adjust your voltage reference to pick up the most interesting one, and play with it. A bit of experimenting should do the trick.... how accurate??? Can't tell... you know, there's some kind of people who have 1 Farad capacitor for their PowerAmp.. how does it affect the noise? I guess experimenting would reveal... on the other side... 1 Farad is no way a decoupling cap
    And oh.. what happen to the noise when you play with your vehicle fan speed? How about when the Radiator fan start/stop?
    Maybe why I wouldn't pick-up the noise from the DC line, but use Hall-Effect (or kind of) sensor instead, directly mounted on the alternator.
  1. Interrupt RPM and Taylors Elapsed time on 18F4620
    Last Post: - 3rd February 2010, 16:12
  2. Pulsin vs. Interrupt RPM measurement
    By Tobias in forum General
    Last Post: - 31st December 2009, 01:29
  3. 16f877A and tmr1 external crystal question
    By comwarrior in forum General
    Last Post: - 13th July 2009, 00:40
  4. RPM - DIV32 Problem
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 11th April 2008, 04:33
  5. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
