MCP41XXX SPI Write
Results 1 to 5 of 5
    May 2007
    Default MCP41XXX SPI Write
    Hi.
    I cannot write a new value to a mcp41010 SPI Digital Potentiometer. What I'm trying to do is
    WriteSPI:
        CS = 0                              ' Enable serial EEPROM
        Shiftout SI, SCK, MSBFIRST, [$06]   ' Send write enable command
        CS = 1                              ' Disable to execute command
        CS = 0                              ' Enable
        Shiftout SI, SCK, MSBFIRST, [$02, 0, 0, UpdPotVal]   ' Send address and data
        CS = 1                              ' Disable
    UpdPotVal goes from 0 to 255
    Can somebody please tell me what I am doing wrong. Here is a C code that does the same thing in case somebody knows how to make use of it!
    #define CS PIN_B4
    #define SCLK PIN_B2
    #define SI PIN_B1
    set_pot (int data) {
       BYTE i;
       BYTE cmd[2];
       cmd[0] = data;
       cmd[1] = 0x11;
       output_low(SCLK);
       output_low(CS);
       for(i=1;i<=16;++i) {
          output_bit(SI, shift_left(cmd,2,0));
          output_high(SCLK);
          output_low(SCLK);
       output_high(CS);
    shutdown_pot () {
       BYTE i;
       BYTE cmd[2];
       cmd[0] = 0;
       cmd[1] = 0x21;
       output_low(SCLK);
       output_low(CS);
          output_high(SCLK);
          output_low(SCLK);
       output_high(CS);
    May 2007
    Ok. I found my problem. If anybody needs this...
    WriteSPI:
        GOSUB GetPotVal
        CS = 0                              ' Enable
        Shiftout SI, SCK, MSBFIRST, [$11, UpdPotVal]
        CS = 1                              ' Disable
    Thanks to me
    Huntsville, AL
    Default SPI write to MCP41010
    I know this thread is a little old, but I'm having a similar problem writing to a MCP41010. I've breadboarded it, and I know the PIC (16F628A) is working because the LED works as it should (I always put that in to make sure the chip's actually operating and running the program).
    Here's the datasheet for the MCP41010:
    http://ww1.microchip.com/downloads/e...Doc/11195c.pdf
    Here's the relevant code:
    cmcon=7
    define osc 8
    res var byte
    command var byte
    SI var porta.4 'SI
    CLK var porta.3 'CLK
    CS var porta.2 'CS
    LED var porta.1 'LED
    high porta.2
    command=19
    high LED
    low LED
    high LED
    repeatit:
    res=256
    low CS
    shiftout SI,CLK,1,[%00010011\8,res\8]
    HIGH CS
    pause 5000
    res=128
    low CS
    shiftout SI,CLK,1,[command,res]
    HIGH CS
    pause 5000
    goto repeatit
    I've tried entering the command like both as binary and a variable to see if that has any effect, but the chip consistently reads 4.7kOhm.
    Any advice or help is appreciated!
    Do you have a pull-up resistor on PORTA.4?
    It has an "Open collector" output, and can't go HIGH by itself.
    Huntsville, AL
    Garsh, I think that's it. I knew there was something about one of the pins I was forgetting. I'll try that tonight and see what happens.
    So long as I use the CMCON=7 command, is porta.4 the only tricky pin I need to worry about? I also set the configuration byte to disable everything.
    Thanks!
  1. WRITE: One more PBP 2.60 Surprise ...
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 26th August 2009, 09:10
  2. Using SPI with External Interrupts
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 04:08
  3. 16-bit SPI problem
    Last Post: - 19th June 2008, 15:42
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  5. Storing Strings using the Write command
    Last Post: - 1st November 2005, 11:31
