PortA digita input?
Results 1 to 3 of 3
    Alabama,USA
    Default PortA digita input?
    I am working on a home project which I would like to use a 16F873A to control a TIP120 Darlington to drive a relay coil. I first check a PortC pin for high or low. If high, I need to read an encoder to select a time delay before triggering the relay.
    I would like to Check for high or low on PortC, read the two bit encoder which will have some value continuously on PortA, display time delay value on PortB, and drive the TIP120 on PortC. As I read about PortA I have some concerns using PortA as digital inputs. Question; using PBP should I set ADCON1= %00000111, TRISA=%11111111. There is a note in the mid range manual that says I may have a high current on pins on PortA as I read the value of the port. Do I have a problem using PortA as digital input?
    TRISB=%00000000
    TRISC=%11110000
    Will PBP handle my concerns?
    Comments will be appreciated.
    Quote Originally Posted by MOUNTAIN747 View Post
    ADCON1 =6 or 7 ok
    NO, as set all port a inputs.
    TRISB=%00000000
    TRISC=%11110000
    Ok, all port b outputs upper half of PortC as inputs,
    set ADCON0=0 , CMCON=7 , and remember RA4 is open drain and requires a pullup resistor.
    Alabama,USA
    Default PortA good to go
    It looks like I'm good to go. Also thanks for mentioning ADCON0 and CMCON, I wasn't sure about that.
    Thanks Joe
  1. PIC Interrupt and PORTA input
    By Jerade in forum mel PIC BASIC
    Last Post: - 29th November 2009, 17:24
  2. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 18:51
  3. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 01:50
  4. PIC16F877 PORTA Input Issue
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 20:33
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 5th May 2005, 23:29
