XOR result different with PC application
Results 1 to 3 of 3
    Aug 2008
    Question XOR result different with PC application
    In Picbasic Pro,
    a var word
    b var word
    c var word
    c = a ^ b
    But using PC to calculate XOR between a and b, I got a different value than c above.
    In both of these cases, when I XOR the result back with b, I can get back a.
    Any idea?
    Sep 2005
    Campbell, CA
    Because "^" is a PBP command for a BITWISE (bit-by-bit) exclusive or. The PC is using a LOGICAL exclusive or. To get the same result as the PC, use the "^^" or XOR PBP commands.
    Charles Linquist
    Quote Originally Posted by Pic2008 View Post
    c = a ^ b
    On a PC, that means a to the power of b.
  1. Send data to PC USB
    By konter in forum Off Topic
    Last Post: - 18th December 2009, 22:57
  2. RS232 into 2 PC ports
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 30th August 2008, 14:33
  3. Sending menu to PC from PIC16F876A
    By joseph Degorio in forum Serial
    Last Post: - 12th November 2007, 08:03
  4. PIC16F877 sends/receives data to/from a PC
    By ovidiu in forum Serial
    Last Post: - 2nd December 2006, 15:09
  5. Interrupt and Serial communication to PC.
    By obaskirt in forum mel PIC BASIC
    Last Post: - 17th June 2005, 21:01
