Using input from Switch to control a loop
Results 1 to 10 of 10
    Dec 2008
    Default Errors still with loop
    Can someone read below, I was told to do this and I am still getting the errors below the code, What am I doing wrong still?
    Thank you in advance.
    code below:
    switch var PortB.0
    if switch =1 then loop 'enter loop
    'forward
    high PORTB.7 'enable pin
    high PORTB.6
    low PORTB.5
    high PORTB.4
    low PORTB.3
    high PORTB.2 'enable pin
    loop:
    if switch=0 then main 'exit the loop
    'backup
    low PORTB.6 'stop this side
    low PORTB.5
    low PORTB.4 'reverse this side
    high PORTB.3
    goto loop
    errors recieved below:
    ERROR Line 13: ':' or '=' Expected (Token 'var') (Loop test2.pbc)
    ERROR Line 13: Illegal Character '.' (Loop test2.pbc)
    ERROR Line 17: Variable Expected (Token 'switch') (Loop test2.pbc)
    ERROR Line 19: Variable or Constant Expected (Token 'PORTB') (Loop test2.pbc)
    ERROR Line 19: Illegal Character '.' (Loop test2.pbc)
    ERROR Line 20: Variable or Constant Expected (Token 'PORTB') (Loop test2.pbc)
    ERROR Line 20: Illegal Character '.' (Loop test2.pbc)
    ERROR Line 21: Variable or Constant Expected (Token 'PORTB') (Loop test2.pbc)
    ERROR Line 21: Illegal Character '.' (Loop test2.pbc)
    ERROR Line 23: Variable or Constant Expected (Token 'PORTB') (Loop test2.pbc)
    ERROR Line 23: Illegal Character '.' (Loop test2.pbc)
    ERROR Line 24: Variable or Constant Expected (Token 'PORTB') (Loop test2.pbc)
    ERROR Line 24: Illegal Character '.' (Loop test2.pbc)
    ERROR Line 25: Variable or Constant Expected (Token 'PORTB') (Loop test2.pbc)
    ERROR Line 25: Illegal Character '.' (Loop test2.pbc)
    ERROR Line 30: Variable Expected (Token 'switch') (Loop test2.pbc)
    ERROR Line 32: Variable or Constant Expected (Token 'PORTB') (Loop test2.pbc)
    ERROR Line 32: Illegal Character '.' (Loop test2.pbc)
    ERROR Line 33: Variable or Constant Expected (Token 'PORTB') (Loop test2.pbc)
    ERROR Line 33: Illegal Character '.' (Loop test2.pbc)
    ERROR Line 34: Variable or Constant Expected (Token 'PORTB') (Loop test2.pbc)
    ERROR Line 34: Illegal Character '.' (Loop test2.pbc)
    ERROR Line 36: Variable or Constant Expected (Token 'PORTB') (Loop test2.pbc)
    ERROR Line 36: Illegal Character '.' (Loop test2.pbc)
    ERROR Line 37: Variable or Constant Expected (Token 'PORTB') (Loop test2.pbc)
    ERROR Line 37: Illegal Character '.' (Loop test2.pbc)
    ERROR Line 38: Variable or Constant Expected (Token 'PORTB') (Loop test2.pbc)
    ERROR Line 38: Illegal Character '.' (Loop test2.pbc)
    By seeing the .pbc extension, I'm I right by saying you have PBC not PBP?
    If so... well.. both are WAY different... PBC don't allow direct addressing to a byte/register bit, and so forth for many other command as well.
    Who have PBC here?
    try this
            SYMBOL PORTB=$06
            symbol TRISB=$86
            POKE TRISB,1 ' PORTB.0 = input, other = output
            POKE PORTB,0 ' Clear all output
            PEEK PORTB,B0
            if BIT0 =1 then goto loop 'enter loop
            'forward
            high 7 'enable pin
            high 6
            low 5
            high 4
            low 3
            high 2 'enable pin
    loop:
            PEEK PORTB,B0
            if BIT0=0 then GOTO main 'exit the loop
            'backup
            high 7 'enable pin
            low 6 'stop this side
            low 5
            low 4 'reverse this side
            high 3
            high 2 'enable pin
            goto loop
    Finger crossed, I don't have PBC
    Dec 2008
    Default What is the difference PBC
    What is the difference of PBC?
    How can I get what you have?
    here's comparision between PBC (PicBasic) and PBP (picBasic Pro)
    http://melabs.com/products/comp_pro.htm
    Depending where you're living, you can purchase it from the following one
    http://melabs.com/purchase.htm#Distributors
    You can also download a limited demo version of PBP.
    http://melabs.com/pbpdemo.htm
  1. Controlsystem for compact sporting (clay shooting)
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 30th July 2009, 17:48
  2. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  3. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 18:42
  4. Remote Control receiver - input source switching
    Last Post: - 16th October 2006, 22:20
  5. How can i control pic input pins order?
    By tanero in forum mel PIC BASIC Pro
    Last Post: - 18th August 2005, 13:46
