Why use a bootloader?
Results 1 to 40 of 41
    France
    Default Re: Why use a bootloader?
    OK Henrick
    Thanks for your reply
    I use a laptop with one COM port (and in MCloader there is no more choice than COM1)
    this COM1 is working with my serial programmer
    It is important that you said ...
    TX and RX lines (via MAX232) goes to RC6 and RC7
    good bootloader file burned in the pic (16F874_20.hex from MCloader directory)
    compilation (using PBP v 2.6) using good define user line (this program "blink" was tested and PIC is OK)
    power on the PIC
    start MCloader .. load hex file ... push program icon .... depress RESET button on PIC board
    download should works beetween the laptop and te PIC ...
    am I right ?
    Hello,
    Yes, when you press Program there should pop up two messages/windows, first one with a progress bar that says Programming and then, when it can't reset the PIC, a second one saying Please reset target microcontroller in order to access the bootloader process... When you reset the PIC the second window will close and you can monitor the progress in the first window, it only takes a couple of seconds depending on the size of the program.
    Have you verified that the serial communication is working, ie by using HSEROUT/HSERIN to send and receive data. Perhaps you've mixed up the RX/TX lines?
    France
    Same player shout again
    I am still in the same marmelade !
    I have checked the hardware RX TX max232 seems good (no mix)
    I will try to test as you said (transmit between PIC and laptop)
    I suspect also that my programmer is not wonderfull
    I must program sometimes 5 times to avoid errors
    I must compare iniatial file from MCloader (16F874_20.hex) with the data burned in the pic !
    I have tried with two differents PIC
    for this week I will be out for 3 days, so, hold the line !
    I lost already 3 days on this crazy thing, no problem because I am retired ! hi ...
    Francois
    France
    Still me, with the same problem
    I spent one day without success !
    abstract : I got garbage using Hserout (to test my RS232 line for bootloader function)
    see my terminal V1.9 log file (hexa dump and ascii dump)
    question :
    What is wrong in my design ?
    I have tested in XT and HS clock mode
    I have changed the MAX232
    LCD and Blink led seems normal (pic is alive !)
    I am lost !
    Thnaks in advance
    Francois
    the program test is the following :
    ' Using PIC 16F874 @ 20MHZ
    DEFINE OSC 20
    ' Set LCD Data port
    DEFINE LCD_DREG PORTD
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 4
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTD
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 2
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTD
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 3
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    ' Hardware configuration
    TRISC = %10000000 ' PORTC.7 is the RX input
    ' PORTC.6 is the TX output
    ' Serial communication definition
    ' Using internal USART and MAX232 to interface to PC
    DEFINE HSER_RCSTA 90h ' enable serial port, enable continuous receive
    DEFINE HSER_TXSTA 20h ' enable transmit, BRGH=1
    DEFINE HSER_SPBRG 129 ' 2400 Baud @ 20MHz, 0,17%
    Pause 500
    start:
    high portd.1
    low portd.1
    lcdout $FE ,1,"test"
    lcdout $FE ,1, "to see"
    hserout ["test TEST"]
    goto start
    France
    Lightbulb STOP : It works !
    Stop it works !
    Now I have the solution to lost one week !
    use a bad Xtal/quartz !
    Pic was running at 6 khz ! instead of 20 Mhz
    just one thing ... put HS (high speed) at the config time(first load) for the bootloader
    second think ... close your terminal program to avoid conflict during MCloader time !
    Thanks for helping me ..
    Francois
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 17:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 23:51
  3. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 22:29
  4. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 17:51
  5. Replies: 3
    Last Post: - 26th January 2005, 13:41
