LCD problem
Results 1 to 9 of 9
Thread: LCD problem
    Thanks guys
    Changing to define osc 48 fixed all the problems, LCD serial everything. Now for the question -- Why???
    On all the other projects you set the define to the cristal freq. but now you set almost 1.5 times higher.
    I am confused can someone PLEASE explain this to me
    Well, look in the datasheet, Oscillator section, and check the available configuration fuses setting. Yes they're a bit tricky to understand...
    From there, you may discover that you can even have a processor speed of 48MHz using a 4MHz crystal... this is accomplished by the internal set of clock divider and PLL.
    As Microchip's bootloader set the Config Fuses for an internal processor speed of 48Mhz, your code must follow it.
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 08:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 19:48
  3. Play with LCD on PICDEM
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 11:43
  5. Need help with LCD number display.
