LCD problem
Results 1 to 9 of 9
Thread: LCD problem
    Hi Andre, Try this, dunno if it will help, but worth a try,
    	LCDOUT $FE,$80
    	LCDOUT "line 1              "
    	LCDOUT $FE, $C0
    	LCDOUT "line 2"
    	PAUSE 1000
    How do you have the OSC configed?
    This might be a clue
    http://www.picbasic.co.uk/forum/show...9&postcount=14
    Dave, I don't think that your link will help because the code show that the OP use MicroChip bootloader.
    One day I should Try it myself
    Main Problem is
    DEFINE OSC 20
    As far as I remember, Microchip Bootloader config fuses and code assume 48MHz BUT with a 20MHz crystal. So I would try
    DEFINE OSC 48
    Well at least I got the OSC 48 part.
    Never used a boot loader though.
    Do you set the configs the same as with out one?
    Most Bootloader I know, will ignore the config fuses in your code as they're already set in their firmware and don't have the ability to re-program them on the fly. HOWEVER, for many PIC18, you can do it later in your code. Darrel Already post something on that... BUT, using this, you will probably screw up most Bootloader... no free lunch
    Bootloader are nice for firmware upgrade, but for development, they have their own limitations.
    Thanks for the info.
    Thanks guys
    Changing to define osc 48 fixed all the problems, LCD serial everything. Now for the question -- Why???
    On all the other projects you set the define to the cristal freq. but now you set almost 1.5 times higher.
    I am confused can someone PLEASE explain this to me
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 08:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 19:48
  3. Play with LCD on PICDEM
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 11:43
  5. Need help with LCD number display.
