Newbie question about switch + led
Results 1 to 12 of 12
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    I don't know what MCU chip you are using but if it has and A/D capability PORT A starts up in Analog mode. If this is the case you can fix the problem by:
    1. Avoiding PORTA or
    2. Looking up the A/D info in the MCU spec. This is often in the ADCON1 register and PORTA made digital by putting something like
    ADCON1 = %00001111
    near the beginning of your code. Good luck
    Regards Bill Legge
    Quote Originally Posted by Bill Legge View Post
    The MCU should be a 16F690 ans A3 doubles as MCLR.
    BTW.
    How are the configs set ?
    Yes correct the MCU is 16F690.
    On the JP5 it is nothing there, just two "soldering holes".
    I don't have a "config set"? The posted code is completely everything i have wrote.
    Maybe i should try to use some other extern components on a breadboard.
    This is what I will bet is happening.
    If you have not changed the *.inc file (configs) MCLR is on.
    When A3 = 0 causes the LED to go high, then when the switch is pressed A3 goes to a hard LOW resetting the PIC. Something like that.
    Yup, move over to a bread board to get started.
    Nah i haven't change anything in the *.inc files.
    I will try with some resistors, switch and led on a breadboard, will get back here when i have tried.
    But so far your eye can see, it isn't anything wrong with the code?
    This is my first real program to PBP, but you get my final point what the program should do right?
    Led = off and when switch is pressed led = on, when switch released led = off.
    Quote Originally Posted by mradde View Post
    Looks "OK" to me.
    biggej's Avatar
    biggej Guest
    The PicKit2 has excellent tutorials. Yes they start with assembler but they will teach you the hardware of the LowPin count board if you read the tutorial. They don't take too long to complete either.
    The advice given by MACKRACKIT is right on target. You must change the .inc file to turn mclr off or the pushbutton will reset the PIC. This is explained in the PicBasicPro example code very well.
    Keep trying. The PicKit and LPC are good learning tools.
    Jim
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. LCD will not start
  4. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 15:30
  5. Greetings from Newbie and a question
    Last Post: - 24th July 2006, 16:52
