Newbie question about switch + led
Results 1 to 12 of 12
    Default Newbie question about switch + led
    start:
    input porta.3
    low portc.0
    If porta.3 = 1 then led   ' when switch is pressed it goes to label "led" right?
    goto start
    led:
    high portc.0    'here should the led light up?
    goto start
    It happens NOTHING with this code.
    If i change the value to "If porta.3 = 0 then led" the led always lights up except when switch is pressed down.
    Any suggestions?
    Quote Originally Posted by mradde View Post
    start:
    input porta.3
    low portc.0
    goto start
    led:
    goto start
    Any suggestions?
    How is everything connected?
    It is the Low Pin Count Demo Board from PICkit2.
    You can see schematic diagram in attached file!
    Do you have JP5 connected?
    Without JP5 connected you will get strange results.
    With JP5 connected A3 will always be high, then when the button is pressed A3 will go low.
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    I don't know what MCU chip you are using but if it has and A/D capability PORT A starts up in Analog mode. If this is the case you can fix the problem by:
    1. Avoiding PORTA or
    2. Looking up the A/D info in the MCU spec. This is often in the ADCON1 register and PORTA made digital by putting something like
    ADCON1 = %00001111
    near the beginning of your code. Good luck
    Regards Bill Legge
    Quote Originally Posted by Bill Legge View Post
    The MCU should be a 16F690 ans A3 doubles as MCLR.
    BTW.
    How are the configs set ?
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. LCD will not start
  4. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 15:30
  5. Greetings from Newbie and a question
    Last Post: - 24th July 2006, 16:52
