POT part values
Results 1 to 8 of 8
Thread: POT part values
    Default POT part values
    I think (don't have the book handy), that POT performs best with specific values
    for the RC network.
    Something like a .1UF cap and 50K pot right?
    So, if I stay in a certain "freq range" will I get the same result?
    Like if I use a 500K pot, that's ok as long as I go down in capacitance?
    Also --
    How long does it take POT to sense the value? You have to stay in a loop?
    For how long?
    THANKS.
    Sep 2008
    Stockholm
    Well, the manual is online..
    http://www.melabs.com/resources/pbpm...8-5_53.htm#550
    I usally try something that looks good, and then test if it works..
    I didnt loop it, ofcoz there is some time it needs to read it, but it can't be very long.
    Here is how I used it in my fancontroller:
    	pot portb.1,Scale,resist0	' read value resist0 with scale scale on port d.1
    	LCDOUT $FE, 1, "Duty = ", #resist0, " ", #pwmfreq, "Hz"
    	HPWM 1,resist0,pwmfreq
    	GoTo main
    The pause is mainly for the LCD, dont think it was needed for the pot command.
    I used a 20K pot and a 220nF cap, with this setup a scale value of 145 was perfect.
    Great -- I'll play with some cap values.
    I'm stuck with a 500K trimmer in an exisiting design.
    Hopefully, POT doesn't take to long to execute as my program needs to keep moving or I could have some problems.
    Thanks.
    Jan 2006
    Istanbul
    Quote Originally Posted by Michael View Post
    Thanks.
    I guess, you will need to use 1nf for 500K pot to get the same linearity as 100nf with 5K POT.
    __________________
    Unhappy
    Hi, Sayzer
    A Happy new year for the Two sides of the Bosphor.
    No ...
    You do have to stick to the 50k - 0.1µF @ 4Mhz harware config. other values will give much limited range and great loss of granularity and precision - Sorry Glenn, but dozen of tests have been run ...
    POT doesn't work at all as RCTime ...
    I think many threads have been launched on this sublect during the past years - including the POT mechanism description ...
    Thanks.
    A definitive answer indeed.
    Guess I'm out of luck then. The cap is there for noise then?
    Sep 2008
    Stockholm
    Well, what can I say, it works fine for me with 20K and 220nf.. I get around zero and 254 at the endstops, and linearity that is good enough for me, actually I just tried to pout the value on a darrel-bargraph (Yea, I do love them ) and it "feels" right when turning the pot looking at the bargraph.
    Maybe its not ideal, but at least its good enough for me, and probably most people ?
    ..But if I can choose the value (In this case there was a pot inbuilt that I wanted to use) I'll think about it.
  1. POT command
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 4th December 2008, 23:33
  2. A/D, Pot, Input, A,B So lost now....
    By Helmutt in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 23:23
  3. Replies: 4
    Last Post: - 24th January 2007, 23:20
  4. t in POT, c's values
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 25th August 2006, 00:30
  5. pot controlled pwm -- help
    Last Post: - 29th January 2006, 13:29
