Is this a valid statement?
Results 1 to 9 of 9
    Oct 2008
    Thanks guys, I haven't tried it yet but I will here in the very near future.
    Don
    Mar 2008
    Default Re: Is this a valid statement?
    Can anyone tell me why this does not work:
    if var8 = 1 then goto beper : J = 3
    The if statement works but J does not = 3 ?
    The J=3 statement isn't executed when VAR8=1 because you're telling to jump to beper.
    If you want to set J=3 when the IF statement is true then
    IF var8 = 1 then
      J=3
      Goto beper
    or simply move J=3 to after the beper label in your program.
    You are exiting the code and jumping to a label "beper". The statement j=3 is never getting executed the way you have written it. If "beper was a subroutine (ie GOSUB beper) then it would be returned to after executing and, set j=3 as the next statement.
    EN82fn
    Mar 2008
    Thank you, that fixes my problem.
  1. 16F883 and Problems with HIGH statement
    By aaanekre in forum mel PIC BASIC Pro
    Last Post: - 29th October 2009, 02:09
  2. END Statement
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 9th November 2008, 15:48
  3. SERIN AND SEROUT PROBELM USING 16f690 PIC
    By Charles in forum mel PIC BASIC Pro
    Last Post: - 18th January 2007, 04:59
  4. Is "PAUSE 0" a valid command
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 19th July 2006, 17:39
  5. getting around the basic IF - THEN statement
    By dw_pic in forum mel PIC BASIC Pro
    Last Post: - 7th February 2006, 15:10
