PBP and 18F2550
Results 1 to 17 of 17
Thread: PBP and 18F2550
    Look in the Analog to digital section... maybe in the comparator section (if there's any)
    Jan 2008
    Yepp i find it
    ADCON1 = %000001111
    sets all AN pins to Digital I/O.
    See "REGISTER 21-2: ADCON1: A/D CONTROL REGISTER 1" in the datasheet for 18F2550
    Thank you...
    Oct 2008
    Default Re: PBP and 18F2550
    Sorry to drag up an old thread but i am struggling to get my head around these registers. I am moving over from using a 16F876A chip and at the moment i cant get the LCD to operate correctly. The characters are displaying but every few cycles they seem to get confused with some noise and random characters appear. Could this be anything to do with having not set the oscillator in the code for my external 4Mhz (I looked for this code but couldn't see any need for it)?
    Thanks for any help!
    'BO = LCD INTERFACE'B1 = LCD INTERFACE
    'B2 = LCD INTERFACE
    'B3 = LCD INTERFACE
    'B4 = LCD INTERFACE
    'B5 = LCD INTERFACE
    'B6 = LCD INTERFACE
    'B7 = LCD INTERFACE
    'C0 = SERVO 1
    'C1 = SERVO 2
    'C2 =
    'C3 =
    'C4 =
    'C5 =
    'C6 =
    'C7 =
    '****************** DEFINE ADCIN PARAMETERS*****************************
       asm
            __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
            __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
            __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L & 0DFh
    endasm
    DEFINE LCD_DREG PORTB 			'Define PIC port used for LCD Data lines
    DEFINE LCD_DBIT 4 			'Define first pin of portb connected to LCD DB4
    DEFINE LCD_RSREG PORTB 			'Define PIC port used for RS line of LCD
    DEFINE LCD_RSBIT 3 			'Define Portb pin used for RS connection
    DEFINE LCD_EREG PORTB 			'Define PIC prot used for E line of LCD
    DEFINE LCD_EBIT 0 			'Define PortB pin used for E connection
    DEFINE LCD_BITS 4 			'Define the 4 bit communication mode to LCD
    DEFINE LCD_LINES 2 			'Define using a 2 line LCD
    DEFINE LCD_COMMANDUS 2000 		'Define delay between sending LCD commands
    DEFINE LCD_DATAUS 50 			'Define delay time between data sent.
    LCDOUT $FE, 1
    pause 10
    LCDOUT $FE, 2
    pause 10
    LCDOUT "3 axis track V1"
    pause 5000
    I'd try this:
    EDIT: This chip (like probably most PICs), has built-in oscillator. Any reason why you don't want to use that?
    And double-check the configuration fuses for the oscillator.
    Oct 2008
    Thanks, I shall try that when I am at home tomorrow evening!
    Only the fact that I was always shown circuits with external ones! Are there many benifits to using the internal ones?
    With the fuses what kind of thing am I looking for or do you know of a beginners guide, as I haven't really dealt with those bits yet!
    Thanks!
    Quote Originally Posted by chrisshortys View Post
    ...Are there many benifits to using the internal ones?...
    Fewer parts, lower cost, less chance of solder problems, less space required on PCB, saving the planet, the list goes on. I've been using external oscillatorsmainly 'cause I bought a bag and enough capacitors, but that might change with USB.
    Thanks!
    The datasheet is your friend:
    http://ww1.microchip.com/downloads/e...Doc/39632e.pdf
    Page 32, section 2-3:
    When these devices are used for USB connectivity,
    they must have either a 6 MHz or 48 MHz clock for
    USB operation, depending on whether Low-Speed or
    Full-Speed mode is being used. This may require some
    forethought in selecting an oscillator frequency and
    programming the device.
    The full range of possible oscillator configurations
    compatible with USB operation is shown in Table 2-3.
    I just pulled out a 18F4550 about 10 minutes ago to get back into USB programming. We share the same datasheet, but I can't comment on config yet, I have to search the forum for examples first. (Here's an interesting thread to start with)
    http://www.picbasic.co.uk/forum/show...18f4550+config
    EDIT: But then it says this under the table:
    Legend: All clock frequencies, except 24 MHz, are exclusively associated with full-speed USB operation (USB clock of 48 MHz).
    Bold is used to highlight clock selections that are compatible with low-speed USB operation (system clock of 24 MHz,
    USB clock of 6 MHz).
    Since several of my PCs don't have USB 2.0, I'll be targetting low speed.
    Oh yes, don't forget that new PCs have USB 3.0, you'll have to look at an expert here to know how to handle that.
    Oct 2008
    I'd try this:
    Hi demon, I haven't had a chance to gt on the pc to try this yet but what would be the difference between using:
    And
    @ __CONFIG _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    @ __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H
    Is the define a pbp level code and the config I'm guessing in asm level?
    I'm not looking at USB yet but I may well try it in future projects!
    I had a look at the data sheet before posting but got very confused and gave in to google which didn't help much either
    I think I may well look to moving to onboard especially if USB will drive off this too!
    Thanks again!
    I'm on cellphone, so sorry for short reply...
    Datasheet says USB requires external oscillator.
    On the internal vs external OSC deal
    I got this from Bruce Reynolds
    If you have a board that will be subject to extreme heat, external will remain constant while internal may vary.
    My opinion is for the cost (minimal), space required on the board (minimal) and chances of solder joint(s) being bad (minimal) I always throw an external on the board.
  1. 18F2550 timing
    By sstt1976 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2008, 01:30
  2. Error compiling 18f2550
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 14th May 2008, 00:22
  3. 18f2550 oscillator problems
    By rjones2102 in forum mel PIC BASIC Pro
    Last Post: - 28th September 2007, 04:57
  4. 18F2550 - config settings
    Last Post: - 13th January 2007, 15:28
  5. ICD2 18F2550 MPASM7.50 - Aargh!
    By Giulio in forum mel PIC BASIC Pro
    Last Post: - 28th November 2006, 18:01
