PBP and 18F2550
Results 1 to 17 of 17
Thread: PBP and 18F2550
    Jan 2008
    I have the Microchip PICKit2 programmer so that PIC is supported.
    I just tryed to recompile a PBP program with the 18F2550 and i have no errors, the PIC starts and the LCD display works but not the serin2 and serout2 commands
    it only sends junk data to the serialcommunicator via a FTDI232 chip.
    When i import the code into the PICKit2 program i get a warning that says "Warning, Some configurations words not in HEX file"
    well i think i have to read some datasheets about the config words i guess.
    Are there any good webpage exept the datasheet that explain all the common configurations words for 18F2550 and how to set them in PBP?
    Apr 2005
    Virginia
    Fredrick,
    Unfortunately, no. You have to search the datasheet quite a bit as every PIC is a little bit different. However, here's a way to make it relatively quick:
    Open the .INC file for your PIC. Assuming you're using Windows and installed everything in the default locations, go to: C:\PBP and open, in this case, 18F2550.INC. You'll see the following open in Notepad.
    ;*  18F2550.INC                                                 *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2007 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 11/08/07                                        *
    ;*  Version   : 2.50a                                           *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F2550, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F2550.INC"	; MPASM  Header
            __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
            __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L & 0DFh
            NOLIST
            LIST
    EEPROM_START	EQU	0F00000h
    BLOCK_SIZE	EQU	32
    Here you see the default configurations PBP makes if you perform no changes. You have two options to change the config settings.
    Method One: modify the config bits as needed (more on this below) and save the file. The only caveat is these settings will take effect in every PIC18F2550 you program unless you remember to change this file each and every time, so it's not typically recommended you do this. Additionally, doing this prevents having people help you with your code if a config setting is wrong or off.
    Method Two: put a semi-colon in front of each and every __CONFIG, like so:
    ;*  18F2550.INC                                                 *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            NOLIST
            LIST
            ;__CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
            ;__CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
            ;__CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
            ;__CONFIG    _CONFIG3H, _PBADEN_OFF_3H
            ;__CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L & 0DFh
            NOLIST
            LIST
    BLOCK_SIZE	EQU	32
    and save the file. All this does is comment out the default config settings so you can use your own in your program. Next, you need to set the config bits within you program, so use the following format at the beginning of your program:
    asm
    endasm
    What can I change is in the next post. Sorry, apparently this is too long for just one reply.
    Apr 2005
    Virginia
    Now the question becomes, what can I change? Glad you asked, again assuming you've got Windows and everything is in the default location, open: C:\Program Files\Microchip\MPASM Suite. Now find and open P18F2550.INC, which will be a fairly large document. Scroll down to the very bottom and you'll see:
    ;       Configuration Bits
    ;   NAME            Address
    ;   CONFIG1L        300000h
    ;   CONFIG1H        300001h
    ;   CONFIG2L        300002h
    ;   CONFIG2H        300003h
    ;   CONFIG3H        300005h
    ;   CONFIG4L        300006h
    ;   CONFIG5L        300008h
    ;   CONFIG5H        300009h
    ;   CONFIG6L        30000Ah
    ;   CONFIG6H        30000Bh
    ;   CONFIG7L        30000Ch
    ;   CONFIG7H        30000Dh
    ; The following is an assignment of address values for all of the
    ; configuration registers for the purpose of table reads
    _CONFIG1L        EQU  H'300000'
    _CONFIG1H        EQU  H'300001'
    _CONFIG2L        EQU  H'300002'
    _CONFIG2H        EQU  H'300003'
    _CONFIG3H        EQU  H'300005'
    _CONFIG4L        EQU  H'300006'
    _CONFIG5L        EQU  H'300008'
    _CONFIG5H        EQU  H'300009'
    _CONFIG6L        EQU  H'30000A'
    _CONFIG6H        EQU  H'30000B'
    _CONFIG7L        EQU  H'30000C'
    _CONFIG7H        EQU  H'30000D'
    ;----- CONFIG1L Options --------------------------------------------------
    _PLLDIV_1_1L         EQU  H'F8'    ; No prescale (4 MHz oscillator input drives PLL directly)
    _PLLDIV_2_1L         EQU  H'F9'    ; Divide by 2 (8 MHz oscillator input)
    _PLLDIV_3_1L         EQU  H'FA'    ; Divide by 3 (12 MHz oscillator input)
    _PLLDIV_4_1L         EQU  H'FB'    ; Divide by 4 (16 MHz oscillator input)
    _PLLDIV_5_1L         EQU  H'FC'    ; Divide by 5 (20 MHz oscillator input)
    _PLLDIV_6_1L         EQU  H'FD'    ; Divide by 6 (24 MHz oscillator input)
    _PLLDIV_10_1L        EQU  H'FE'    ; Divide by 10 (40 MHz oscillator input)
    _PLLDIV_12_1L        EQU  H'FF'    ; Divide by 12 (48 MHz oscillator input)
    _CPUDIV_OSC1_PLL2_1L EQU  H'E7'    ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
    _CPUDIV_OSC2_PLL3_1L EQU  H'EF'    ; [OSC1/OSC2 Src: /2][96 MHz PLL Src: /3]
    _CPUDIV_OSC3_PLL4_1L EQU  H'F7'    ; [OSC1/OSC2 Src: /3][96 MHz PLL Src: /4]
    _CPUDIV_OSC4_PLL6_1L EQU  H'FF'    ; [OSC1/OSC2 Src: /4][96 MHz PLL Src: /6]
    _USBDIV_1_1L         EQU  H'DF'    ; USB clock source comes directly from the primary oscillator block with no postscale
    _USBDIV_2_1L         EQU  H'FF'    ; USB clock source comes from the 96 MHz PLL divided by 2
    ;----- CONFIG1H Options --------------------------------------------------
    _FOSC_XT_XT_1H       EQU  H'F0'    ; XT oscillator, XT used by USB
    _FOSC_XTPLL_XT_1H    EQU  H'F2'    ; XT oscillator, PLL enabled, XT used by USB
    _FOSC_ECIO_EC_1H     EQU  H'F4'    ; External clock, port function on RA6, EC used by USB
    _FOSC_EC_EC_1H       EQU  H'F5'    ; External clock, CLKOUT on RA6, EC used by USB
    _FOSC_ECPLLIO_EC_1H  EQU  H'F6'    ; External clock, PLL enabled, port function on RA6, EC used by USB
    _FOSC_ECPLL_EC_1H    EQU  H'F7'    ; External clock, PLL enabled, CLKOUT on RA6, EC used by USB
    _FOSC_INTOSCIO_EC_1H EQU  H'F8'    ; Internal oscillator, port function on RA6, EC used by USB
    _FOSC_INTOSC_EC_1H   EQU  H'F9'    ; Internal oscillator, CLKOUT on RA6, EC used by USB
    _FOSC_INTOSC_XT_1H   EQU  H'FA'    ; Internal oscillator, XT used by USB
    _FOSC_INTOSC_HS_1H   EQU  H'FB'    ; Internal oscillator, HS used by USB
    _FOSC_HS_1H          EQU  H'FC'    ; HS oscillator, HS used by USB
    _FOSC_HSPLL_HS_1H    EQU  H'FE'    ; HS oscillator, PLL enabled, HS used by USB
    _FCMEN_OFF_1H        EQU  H'BF'    ; Fail-Safe Clock Monitor disabled
    _FCMEN_ON_1H         EQU  H'FF'    ; Fail-Safe Clock Monitor enabled
    _IESO_OFF_1H         EQU  H'7F'    ; Oscillator Switchover mode disabled
    _IESO_ON_1H          EQU  H'FF'    ; Oscillator Switchover mode enabled
    ;----- CONFIG2L Options --------------------------------------------------
    _PWRT_ON_2L          EQU  H'FE'    ; PWRT enabled
    _PWRT_OFF_2L         EQU  H'FF'    ; PWRT disabled
    _BOR_OFF_2L          EQU  H'F9'    ; Brown-out Reset disabled in hardware and software
    _BOR_SOFT_2L         EQU  H'FB'    ; Brown-out Reset enabled and controlled by software (SBOREN is enabled)
    _BOR_ON_ACTIVE_2L    EQU  H'FD'    ; Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
    _BOR_ON_2L           EQU  H'FF'    ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
    _BORV_0_2L           EQU  H'E7'    ; Maximum setting
    _BORV_1_2L           EQU  H'EF'    ;
    _BORV_2_2L           EQU  H'F7'    ;
    _BORV_3_2L           EQU  H'FF'    ; Minimum setting
    _VREGEN_OFF_2L       EQU  H'DF'    ; USB voltage regulator disabled
    _VREGEN_ON_2L        EQU  H'FF'    ; USB voltage regulator enabled
    ;----- CONFIG2H Options --------------------------------------------------
    _WDT_OFF_2H          EQU  H'FE'    ; HW Disabled - SW Controlled
    _WDT_ON_2H           EQU  H'FF'    ; HW Enabled - SW Disabled
    _WDTPS_1_2H          EQU  H'E1'    ; 1:1
    _WDTPS_2_2H          EQU  H'E3'    ; 1:2
    _WDTPS_4_2H          EQU  H'E5'    ; 1:4
    _WDTPS_8_2H          EQU  H'E7'    ; 1:8
    _WDTPS_16_2H         EQU  H'E9'    ; 1:16
    _WDTPS_32_2H         EQU  H'EB'    ; 1:32
    _WDTPS_64_2H         EQU  H'ED'    ; 1:64
    _WDTPS_128_2H        EQU  H'EF'    ; 1:128
    _WDTPS_256_2H        EQU  H'F1'    ; 1:256
    _WDTPS_512_2H        EQU  H'F3'    ; 1:512
    _WDTPS_1024_2H       EQU  H'F5'    ; 1:1024
    _WDTPS_2048_2H       EQU  H'F7'    ; 1:2048
    _WDTPS_4096_2H       EQU  H'F9'    ; 1:4096
    _WDTPS_8192_2H       EQU  H'FB'    ; 1:8192
    _WDTPS_16384_2H      EQU  H'FD'    ; 1:16384
    _WDTPS_32768_2H      EQU  H'FF'    ; 1:32768
    This is just a portion of all the configuration options, you'll have to open it up to see them all. Note that this chip has multiple config registers, so be sure to match up the desired setting with the proper register. The tedious part will be looking up what each of these mean in the datasheet if you don't already know. Off the bat, in register CONFIG2H I know WDT is watchdog timer and for most programs, I turn it off, but you may want it. I usually copy the config settings I don't recognize and perform a find (CTRL + F) in the datasheet. This may not always work as the abbriviations in the .INC file may not be in the datasheet, but a little searching and you'll find it. Hope this helps.
    -Tony
    Jan 2008
    Thank you very much Tony.
    That helped alot, now SERIN and SEROUT are working.
    Now i trying to figure out how to make RA5 to digital input/output.
    Look in the Analog to digital section... maybe in the comparator section (if there's any)
    Jan 2008
    Yepp i find it
    ADCON1 = %000001111
    sets all AN pins to Digital I/O.
    See "REGISTER 21-2: ADCON1: A/D CONTROL REGISTER 1" in the datasheet for 18F2550
    Thank you...
    Oct 2008
    Default Re: PBP and 18F2550
    Sorry to drag up an old thread but i am struggling to get my head around these registers. I am moving over from using a 16F876A chip and at the moment i cant get the LCD to operate correctly. The characters are displaying but every few cycles they seem to get confused with some noise and random characters appear. Could this be anything to do with having not set the oscillator in the code for my external 4Mhz (I looked for this code but couldn't see any need for it)?
    Thanks for any help!
    'BO = LCD INTERFACE'B1 = LCD INTERFACE
    'B2 = LCD INTERFACE
    'B3 = LCD INTERFACE
    'B4 = LCD INTERFACE
    'B5 = LCD INTERFACE
    'B6 = LCD INTERFACE
    'B7 = LCD INTERFACE
    'C0 = SERVO 1
    'C1 = SERVO 2
    'C2 =
    'C3 =
    'C4 =
    'C5 =
    'C6 =
    'C7 =
    '****************** DEFINE ADCIN PARAMETERS*****************************
       asm
            __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
    endasm
    DEFINE LCD_DREG PORTB 			'Define PIC port used for LCD Data lines
    DEFINE LCD_DBIT 4 			'Define first pin of portb connected to LCD DB4
    DEFINE LCD_RSREG PORTB 			'Define PIC port used for RS line of LCD
    DEFINE LCD_RSBIT 3 			'Define Portb pin used for RS connection
    DEFINE LCD_EREG PORTB 			'Define PIC prot used for E line of LCD
    DEFINE LCD_EBIT 0 			'Define PortB pin used for E connection
    DEFINE LCD_BITS 4 			'Define the 4 bit communication mode to LCD
    DEFINE LCD_LINES 2 			'Define using a 2 line LCD
    DEFINE LCD_COMMANDUS 2000 		'Define delay between sending LCD commands
    DEFINE LCD_DATAUS 50 			'Define delay time between data sent.
    LCDOUT $FE, 1
    pause 10
    LCDOUT $FE, 2
    pause 10
    LCDOUT "3 axis track V1"
    pause 5000
  1. 18F2550 timing
    By sstt1976 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2008, 01:30
  2. Error compiling 18f2550
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 14th May 2008, 00:22
  3. 18f2550 oscillator problems
    By rjones2102 in forum mel PIC BASIC Pro
    Last Post: - 28th September 2007, 04:57
  4. 18F2550 - config settings
    Last Post: - 13th January 2007, 15:28
  5. ICD2 18F2550 MPASM7.50 - Aargh!
    By Giulio in forum mel PIC BASIC Pro
    Last Post: - 28th November 2006, 18:01
