Please help with basic math
Results 1 to 4 of 4
    Apr 2008
    Default Please help with basic math
    Hi guys and girls....
    Just wondering if you can help me with some basic maths.
    I have programmed a chip for some simple phase control however I need to workout the average power given the firing angle.
    searching the internet I found the equation:
    average power = Vpk/4*pi*R [pi - angle+1/2*sin(2*angle)]
    I HAVE NO IDEA HOW TO TYPE THIS INTO A CALCULATOR!
    The angle 1/2 bit does my head in. Can somebody please translate this equation to a simpleton and do it as simple as possible.
    cheers..
    Default Re: Please help with basic math
    Hi, That's not too difficult ... to use it with PBP
    1) Pi (3.141592654 ...)
    replace it by integer fraction like 22/7 or 355/113
    2) here, angles are expressed in radians ... just change to BINARY radians PBP can deal with
    2*pi rads = 360° = 255 binary radians ...
    and keep a sharp eye on overflows ( depending on the processor used : 16F - 16 Bits unsigned, 18F with longs - 31 signed bits )
    That's all !!!
    looks it applies to a resistive load ( lamp, heather ...) but not to inductive loads ... like motors.
    Apr 2008
    That's all !!!
    Thanks for your reply Alain but before I can try to implement the equation into the programme I need to know how to calculate it with a calculator.
    The answer is meant to be 480W but I don't get close to it. The bit in brackets comes out with a negative number??
    Should have stayed at school I guess..
    Perth, Australia
    The angle needs to be in radians. If you multiply the angle in degrees by Pi/180 you will get the angle in radians.
    When you do so, it comes out to 480. (http://www.wolframalpha.com/input/?i...5*(Pi%2F180))))
