Trouble with PIC16F88 (chip hangs up)
Results 1 to 3 of 3
    Default Trouble with PIC16F88 (chip hangs up)
    I checked the configuration bits - all seems ok, but the problem is still alive.
    I would be thankfull for a good idea?
    Wink
    Are you sure the supply voltage goes to < 1 v when you re-apply power ???
    Easy confirm :
    1) Turn MCLR to ON AND Always let The Watchdog ON if no valuable reason to cancel it ( @ Sleep ...i.e.)
    wdt_off, MCLR_off
    I'm not not kidding, here ... but ... I could !!!
    2) enable the Brownout function ...
    3) Allow the Power-up Timer ...
    4) use a R/C/D reset circuit instead of a simple resistor ( Datasheet $15.2 )
  1. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 00:13
  2. PICKIT2 - PBC Pro - PIC16F88 TROUBLE
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2008, 23:37
  3. ADC trouble with PIC16F88
    Last Post: - 3rd December 2008, 12:56
  4. Replies: 8
    Last Post: - 7th December 2006, 15:42
  5. chip selection aid
    By PICMAN in forum General
    Last Post: - 21st February 2005, 18:33
