Hello, I´m new using the PBP.
My programm shall be an PWM Controller for RGB LED.
I´m using a PIC16F88.
PortB is Digital Output (PWM 250Hz), PortA is Digital Input.
Is there something special at this chip (register/ansel/cmcon..) to watch for?
The MCLR is connected with 4k7 to VDD (Must this be? I would like to use this pin also as an high-active input)
When I apply Power (Power Supply is good, 100n attached) it works some times correct. When I apply power next time, chip hangs up
(outputs blinking undefined, chip is touch-sensitive). It seems as if any initialisation failes?? (no tris-setting?, but therefore I put already a pause 1000 in the beginning)
Thanks in Advance
(Sorry for my German-English)
Best regards
Norbert
Code:REM Prozessordefinitionen und Register setzen define osc4 osccon = $60 @ DEVICE INTRC_OSC, lvp_off, wdt_off, MCLR_off cmcon = 7 ansel=0 pause 1000 trisa=%11101111 REM RA4=Ausgang, alle anderen Eingang trisb=%00000000 REM RB=Ausgang disable ROTWERT var word GRUENWERT VAR WORD BLAUWERT VAR WORD SCHNELLZAEHL var word SCHNELLWERT VAR WORD SCHNELLWERTZAEHL VAR WORD TASTEEIN VAR BYTE ROT var word GRUEN var word BLAU var word LET SCHNELLWERT=30 LET SCHNELLWERTZAEHL=0 let SCHNELLZAEHL=1 LET TASTEEIN=0 let ROT=0 let GRUEN=0 LET BLAU=0 REM Programmstart REM----------------------------------------------------------------------------- REM ANFANG SCHWELLER porta.4=1 portb=%11111111 SCHWELLER: REM Rote LED wird von dunkel nach hell gesteuert let ROT=0 for ROTWERT = 40 to 4000 step 40 for SCHNELLZAEHL = 1 to SCHNELLWERT porta.4=1 portb.2=1 portb.5=1 gosub TASTE if tasteein=3 then let ROT=ROTWERT IF TASTEEIN>=1 then GOTO TASTENWERK pauseus 4000-ROTWERT porta.4=0 portb.2=0 portb.5=0 pauseus ROTWERT next SCHNELLZAEHL next ROTWERT let rot=4000 REM Gruene LED wird von dunkel nach hell gesteuert let GRUEN=0 for GRUENWERT = 40 to 4000 step 40 for SCHNELLZAEHL = 1 to SCHNELLWERT portb.1=1 portb.4=1 portb.7=1 gosub TASTE if tasteein=3 then let gruen=gruenwert IF TASTEEIN>=1 then GOTO TASTENWERK pauseus 4000-GRUENWERT portb.1=0 portb.4=0 portb.7=0 pauseus GRUENWERT next SCHNELLZAEHL next GRUENWERT LET gruen=4000 REM Blaue LED wird von dunkel nach hell gesteuert let blau=0 for BLAUWERT = 40 to 4000 step 40 for SCHNELLZAEHL = 1 to SCHNELLWERT portb.0=1 portb.3=1 portb.6=1 gosub TASTE if tasteein=3 then let blau=blauwert IF TASTEEIN>=1 then GOTO TASTENWERK pauseus 4000-BLAUWERT portb.0=0 portb.3=0 portb.6=0 pauseus BLAUWERT next SCHNELLZAEHL next BLAUWERT let blau=4000 REM Gruene LED wird von hell nach dunkel gesteuert let gruen=4000 for GRUENWERT = 4000 to 200 step -40 for SCHNELLZAEHL = 1 to SCHNELLWERT portb.1=0 portb.4=0 portb.7=0 pauseus GRUENWERT portb.1=1 portb.4=1 portb.7=1 gosub TASTE if tasteein=3 then let gruen=gruenwert IF TASTEEIN>=1 then GOTO TASTENWERK pauseus 4000-GRUENWERT next SCHNELLZAEHL next GRUENWERT LET gruen=0 REM Rote LED wird von hell nach dunkel gesteuert let rot=4000 for ROTWERT = 4000 to 200 step -40 for SCHNELLZAEHL = 1 to SCHNELLWERT porta.4=0 portb.2=0 portb.5=0 pauseus ROTWERT porta.4=1 portb.2=1 portb.5=1 gosub TASTE if tasteein=3 then let rot=rotwert IF TASTEEIN>=1 then GOTO TASTENWERK pauseus 4000-ROTWERT next SCHNELLZAEHL next ROTWERT LET rot=0 REM Blaue LED wird von hell nach dunkel gesteuert let blau=4000 for BLAUWERT = 4000 to 200 step -40 for SCHNELLZAEHL = 1 to SCHNELLWERT portb.0=0 portb.3=0 portb.6=0 pauseus BLAUWERT portb.0=1 portb.3=1 portb.6=1 gosub TASTE if tasteein=3 then let blau=blauwert IF TASTEEIN>=1 then GOTO TASTENWERK pauseus 4000-BLAUWERT next SCHNELLZAEHL next BLAUWERT let blau=0 goto SCHWELLER REM ENDE SCHWELLER REM----------------------------------------------------------------------------- REM ANFANG STATISCH ROT, GRUEN, BLAU STATISCH_ROT: rem rot_an porta.4=0 portb.2=0 portb.5=0 rem blau_aus portb.0=1 portb.3=1 portb.6=1 rem gruen_aus portb.1=1 portb.4=1 portb.7=1 gosub taste IF TASTEEIN>=1 then GOTO TASTENWERK goto statisch_rot STATISCH_GRUEN: rem rot_aus porta.4=1 portb.2=1 portb.5=1 rem blau_aus portb.0=1 portb.3=1 portb.6=1 rem gruen_an portb.1=0 portb.4=0 portb.7=0 gosub taste IF TASTEEIN>=1 then GOTO TASTENWERK goto statisch_gruen STATISCH_BLAU: rem rot_aus porta.4=1 portb.2=1 portb.5=1 rem blau_an portb.0=0 portb.3=0 portb.6=0 rem gruen_aus portb.1=1 portb.4=1 portb.7=1 gosub taste IF TASTEEIN>=1 then GOTO TASTENWERK goto statisch_blau REM ENDE STATISCH ROT, GRUEN, BLAU REM----------------------------------------------------------------------------- REM START STATISCHES LICHT AUS GESTOPPTEN SCHWELLER SCH_STAT: REM ROTER STATISCHER WERT AUS SCHWELLER porta.4=0 portb.2=0 portb.5=0 pauseus ROT porta.4=1 portb.2=1 portb.5=1 pauseus 4000-ROT REM GRUENER STATISCHER WERT AUS SCHWELLER portb.1=0 portb.4=0 portb.7=0 pauseus GRUEN portb.1=1 portb.4=1 portb.7=1 pauseus 4000-GRUEN REM BLAUER STATISCHER WERT AUS SCHWELLER portb.0=0 Portb.3=0 portb.6=0 pauseus BLAU portb.0=1 portb.3=1 portb.6=1 pauseus 4000-BLAU gosub taste IF TASTEEIN>=1 then GOTO TASTENWERK GOTO SCH_STAT REM ENDE STATISCHES LICHT AUS GESTOPPTEN SCHWELLER REM----------------------------------------------------------------------------- REM ANFANG ZUORDNUNG DER GEDRÜCKTEN TASTE ZU EINER VARIABLEN TASTE: let tasteein=0 'if porta.0=1 then let TASTEEIN=1 'IF porta.1=1 then let tasteein=2 'if porta.2=1 then let tasteein=3 'if porta.3=1 then let tasteein=4 'if porta.5=0 then let tasteein=5 'if porta.6=1 then let tasteein=6 'if porta.7=1 then let tasteein=7 RETURN REM ENDE ZUORDNUNG DER GEDRÜCKTEN TASTE ZU EINER VARIABLEN REM----------------------------------------------------------------------------- REM ANFANG AUSWAHL DER MODULE TASTENWERK: PAUSE 100 select case tasteein case 1 goto EIN case 2 goto schnell case 3 goto sch_stat case 4 goto AUS case 5 goto statisch_rot case 6 goto statisch_gruen case 7 goto statisch_Blau end select let tasteein=0 goto schweller REM ENDE AUSWAHL DER MODULE REM----------------------------------------------------------------------------- REM ANFANG EIN EIN: READ 0,ROT.byte0 READ 1,ROT.byte1 read 2,BLAU.byte0 read 3,blau.byte1 read 4,gruen.byte0 read 5,gruen.byte1 pause 100 goto sch_stat REM ENDE EIN REM----------------------------------------------------------------------------- REM ANFANG AUS AUS: write 0,rot.byte0 write 1,rot.byte1 write 2,blau.byte0 write 3,blau.byte1 write 4,gruen.byte0 write 5,gruen.byte1 pause 10 AUSAUS: porta.4=1 portb.2=1 portb.5=1 portb.0=1 portb.3=1 portb.6=1 portb.1=1 portb.4=1 portb.7=1 gosub taste IF TASTEEIN>=1 then GOTO TASTENWERK goto ausaus REM ENDE AUS REM----------------------------------------------------------------------------- REM ANFANG GESCHWINDIGKEITSEINSTELLUNG SCHWELLER SCHNELL: pause 100 let SCHNELLWERTZAEHL=SCHNELLWERTZAEHL+1 IF SCHNELLWERTZAEHL=4 THEN LET SCHNELLWERTZAEHL=1 SELECT CASE SCHNELLWERTZAEHL CASE 1 SCHNELLWERT=5 CASE 2 SCHNELLWERT=15 CASE 3 SCHNELLWERT=30 END SELECT let SCHNELLZAEHL=1 let tasteein=0 GOTO SCHWELLER REM ENDE GESCHWINDIGKEITSEINSTELLUNG SCHWELLER REM----------------------------------------------------------------------------- END
