debug error on 12F509
Results 1 to 8 of 8
    Pedro Pinto's Avatar
    Pedro Pinto Guest
    Default debug error on 12F509
    Hello
    dat var word
    I want use the pic 12F509
    this instruction compile fine
    debug "Hello",dat,10,13
    but this donīt compile
    debug "Hello",BIN16 dat,10,13
    the compile show this error messages
    ERROR: Macro DEBUGCOUNT?C not found in macro file
    ERROR: Macro DEBUGNUM?W not found in macro file
    ERROR: Macro DEBUGBIN? not found in macro file
    PBP Pro 2.50
    Anyone know what is the problem?
    Best regards
    Pedro
    Did you put the DEBUG DEFINES in your code?
    Pedro Pinto Guest
    Hello Joe S
    Yes, i put
    DEFINE DEBUG_REG GPIO
    DEFINE DEBUG_BIT 4
    DEFINE DEBUG_BAUD 2400
    DEFINE DEBUG_MODE 1
    DEFINE DEBUG_PACING 1000
    This didn't also work too
    tipo var byte
    iplp var GPIO.5
    bmode CON 4 ' N2400 INVERTED
    inicio:
    pause 1
    SERIN2 iplp,bmode,800,inicio,[wait ("C"),HEX2 tipo]
    Anyone a idea?
    Perhaps the 12F serie don't work with the serin2
    and also have problems to send like, dec var, hex var, bin var
    This work
    SerIn iplp,4,["OK"],andar
    This not work
    SerIn iplp,4,["OK"],#andar
    Best regards
    Pedro
    Some things (pretty much everything you're showing) just are not supported on 12-bit core.
    http://www.melabs.com/support/12-bit.htm
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Pedro Pinto Guest
    Hello Bruce
    With the 12F609 it works, the compiler not show any errors
    If i add on program begin the instruction to tune the internal oscilator
    the compiler show a error message, do i not need to add the
    DEFINE OSCCAL_2K 1 on the begin of the code?
    Pedro
    Hi Pedro,
    It shouldn't show any errors. The 12F609 is a 14-bit core. The 12F509 is a 12-bit core.
    DEFINE OSCCAL_2K 1 is for a 2K part. DEFINE OSCCAL_1K 1 would be for a 1K part, but this isn't necessary for a PIC that doesn't have a factory OSCCAL calibration value stuffed in the last program memory location or an OSCCAL register
    -Bruce
    tech at rentron.com
  1. N-Bit_MATH
    Last Post: - 16th December 2010, 15:48
  2. About USB
    By dias11 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 21:41
  3. debug not working with MPASM assempler
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 4th March 2009, 08:51
  4. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
  5. Debug and some 18F pics
    By sinoteq in forum mel PIC BASIC Pro
    Last Post: - 21st June 2007, 16:10
