Newbie need Help 16F627a
Results 1 to 15 of 15
Threaded View
  1. #6
    Quote Originally Posted by azmax100 View Post
    Hi all.
    thanks for the reply.
    Joe S. I'm using 20mhz xtal. After Define still the same.
    OK 20 mhz will not work with the default config statement, to use 20 mhz you must change it or comment it out of the PIC16F627A.INC file located in the PBP Directory. The Default config is set to use XT_OSC and the 20 mhz requires HS_OSC, what it does internaly is to provide the oscillator with more power, as it is needed to run that fast. Study this link : http://www.picbasic.co.uk/forum/showthread.php?t=543 As for the MCLR PIN tie a resistor about 5k ohm from mclr to thr 5v+ supply. To reset the PIC you then momentaraly ground it, OR in the config statement you turn it off and use it as an I/O.
  1. Newbie making an ignition timer
    Last Post: - 5th August 2012, 18:45
  2. Newbie: Temperature measurements
    By Budda in forum General
    Last Post: - 30th March 2007, 10:56
  3. PIC Newbie
    By azmax100 in forum Schematics
    Last Post: - 23rd February 2007, 05:52
  4. request for a newbie forum
    By nimonia in forum Forum Requests
    Last Post: - 20th May 2006, 10:01
  5. 16F627A portA4 problem?
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 22nd October 2005, 20:54
