Newbie Pause Question
Results 1 to 3 of 3
    Dec 2008
    Default Newbie Pause Question
    Is it possible to use a variable with the Pause command?
    Here's my code. It seems to compile but won't run on my 16f88. To test it I connected an LED to Port A.2 that should flash on/off with longer and longer duration:
    i var word
    ii var word
    ii = 200
    For i = 1 to 100
    HIGH PORTA.2 ' Turn on LED connected to PORTA.2
    Pause ii ' Delay
    Low PORTA.2 ' Turn off LED connected to PORTA.2
    Pause ii ' Delay
    ii = ii + 200
    Next i
    Your code should work as described.
    Well ... barring other problems like ... Analog mode or CONFIGs.
    Possibly ...
    Presetting Configuration Fuses (PIC Defines) into your Program
    Another good thread ...
    PortA Doesn't Work
    Dec 2008
    Thanks Darrel
    Turns out it was a bad LED.
    Yes, Pause can be used with a variable.
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 07:28
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. Replies: 11
    Last Post: - 12th July 2008, 03:36
  4. Fade out LEDs question
    By Sam in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2008, 11:50
  5. Help Quick Need to make code smaller
    By Programmednew in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 04:46
