Oxygen Sensor
Results 1 to 3 of 3
Thread: Oxygen Sensor
    Hi, Sammy
    What do you call an Oxygen sensor ???
    - a "classical" lambdaprobe ? ( Make, model ??? )
    - a "Wideband" lambdaprobe ? ( Make, Model ??? )
    - a real Oxygen sensor like Figaro's : http://figaro.co.jp/en/make_html/item_2_sen_112280.html
    without any model ... no chance to know what and how to measure !!!
    BUT ... what you'll have to build is a simple voltmeter ... generally made with LM3914 chips ...
    May 2006
    Hi Alain:
    Thanx for your reply.It is the Wideband lambdaprobe that I am intrested in. I have worked with the Figaro's sensor and it works great. There is no need to heat the sensor. My problem is that with a lambda sensor, I am not sure how much circuitry is needed for the heating part of the sensor. Also I am not sure what make and model I can use. I have no idea what part number I am looking at. Any idea regarding the heating section would help as well.
    Thank you again
    Sam
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  3. Ultrasonic distance sensor with PIC16F84A
    Last Post: - 29th June 2009, 10:01
  4. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 01:05
  5. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 16:55
