Oxygen Sensor
Results 1 to 3 of 3
Thread: Oxygen Sensor
    May 2006
    Default Oxygen Sensor
    Hi:
    I am not sure if anyone can help me here. I am trying to see if anyone knows how a car oxygen sensor can be read with the ADC of a pic. Anyone has any idea how to do this and what type of oxygen seonsor can be used. There is so many models out there for different cars that any information will be great. A circuit would even be better.
    Thank you
    Sam
    Hi, Sammy
    What do you call an Oxygen sensor ???
    - a "classical" lambdaprobe ? ( Make, model ??? )
    - a "Wideband" lambdaprobe ? ( Make, Model ??? )
    - a real Oxygen sensor like Figaro's : http://figaro.co.jp/en/make_html/item_2_sen_112280.html
    without any model ... no chance to know what and how to measure !!!
    BUT ... what you'll have to build is a simple voltmeter ... generally made with LM3914 chips ...
    May 2006
    Hi Alain:
    Thanx for your reply.It is the Wideband lambdaprobe that I am intrested in. I have worked with the Figaro's sensor and it works great. There is no need to heat the sensor. My problem is that with a lambda sensor, I am not sure how much circuitry is needed for the heating part of the sensor. Also I am not sure what make and model I can use. I have no idea what part number I am looking at. Any idea regarding the heating section would help as well.
    Thank you again
    Sam
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 22:42
  2. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  3. Ultrasonic distance sensor with PIC16F84A
    Last Post: - 29th June 2009, 09:01
  4. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 00:05
  5. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 15:55
