Hi all, I made a RGB LED lamp with super bright RGB LEDs from sparkfun and control the color from my TV remote. I use 16F628s X2 because I couldnt get pulsein to work with MIBAM (inturupt timming issue) Here is the code if it will help anyone. Its not real clean but it works well
Aaron
IR CODE
'*  Name    : IR_RGB_ControlV2
'*  Author  : Aaron E.Wilson
'*  Notice  : Copyright (c) 2009
'*          : All Rights Reserved
'*  Date    : 2/21/2009
'*  Version : 1.0
'*  Notes   : Sets RGB select ports and UP/DN ports from IR remote
define osc 4
CMCON     = 7          ' PortA = digital I/O
VRCON     = 0          ' A/D Voltage reference disabled
TRISA     = %00000010  ' Set PortA I/O
TRISB     = %00000000  ' Set PortB I/O
PORTA     = 0          ' Clear PortA
PORTB     = 0          ' Clear PortB
IRpulse_length var word(13)
xx var Byte
Command	Var	Byte
Device Var Byte        'IR Chip---------RGB Chip
IR_IN var PORTA.1       'Pin 18         N/A
RED_SEL var PORTB.1     'Pin 7          Pin 18
BLUE_SEL var PORTB.2    'Pin 8          Pin 3
GREEN_SEL var PORTB.3   'Pin 9          Pin 17
UP var PORTB.5          'Pin 11         Pin 1
DN var PORTB.4          'Pin 10         Pin 2
    gosub ReadIr
    if command = 1 then RED_Adj
    if command = 2 then BLUE_Adj
    if command = 3 then GREEN_Adj
goto Main
Red_Adj:
    blue_sel = 0
    Green_sel = 0
    red_sel = 1
    gosub ReadIr
    if command = 17 then
    dn = 0
    up = 1
    up = 0
    if command = 18 then
    up = 0
    dn = 1
    dn = 0
    goto red_adj
BLUE_Adj:
    red_sel = 0
    green_sel = 0
    blue_sel = 1
    gosub ReadIr
    dn = 0
    up = 1
    up = 0
    up = 0
    dn = 1
    dn = 0
    if command = 1 then red_Adj
    goto blue_adj
GREEN_Adj:
    red_sel = 0
    Blue_sel = 0
    green_sel = 1
    gosub ReadIr
    dn = 0
    up = 1
    up = 0
    up = 0
    dn = 1
    dn = 0
    goto green_adj
ReadIR:
    PuLSIN IR_IN,0,IRpulse_length(0)
    if IRpulse_length(0) < 200 then
    goto ReadIR
    Endif
    for xx=1 to 12
    pulsin ir_in,0,IRpulse_length(xx)
    next  xx
    if IRpulse_length(1) < 100 then
    Command.bit0 = 0
    Else
    Command.bit0 = 1
    if IRpulse_length(2) < 100 then
    Command.bit1 = 0
    Else
    Command.bit1 = 1
    if IRpulse_length(3) < 100 then
    Command.bit2 = 0
    Else
    Command.bit2 = 1
    if IRpulse_length(4) < 100 then
    Command.bit3 = 0
    Else
    Command.bit3 = 1
    if IRpulse_length(5) < 100 then
    Command.bit4 = 0
    Else
    Command.bit4 = 1
    if IRpulse_length(6) < 100 then
    Command.bit5 = 0
    Else
    Command.bit5 = 1
    if IRpulse_length(7) < 100 then
    Command.bit6 = 0
    Else
    Command.bit6 = 1
    Command.bit7 = 0
    Command = Command + 1
    If Command = 10 then
    Command = 0
    Endif
    if IRpulse_length(8) < 100 then
    Device.bit0 = 0
    Else
    Device.bit0 = 1
    if IRpulse_length(9) < 100 then
    Device.bit1 = 0
    Else
    Device.bit1 = 1
    if IRpulse_length(10) < 100 then
    Device.bit2 = 0
    Else
    Device.bit2 = 1
    if IRpulse_length(11) < 100 then
    Device.bit3 = 0
    Else
    Device.bit3 = 1
DebugInfo:
SEROUT2 PORTA.0,16780,[13]
SEROUT2 PORTA.0,16780,[10]
SEROUT2 PORTA.0,16780,["Device ", dec Device, " Command ", dec command]
MIBAM CODE
'*  Name    : Adj_Color
'*  Date    : 2/22/2009
'*  Version : Final
'*  Notes   :
;_________________________Interrupt Context save locations]_________________
wsave       var byte    $20     SYSTEM      ' location for W if in bank0
wsave1      VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
wsave2      VAR BYTE    $120    SYSTEM      ' location for W if in bank2
ssave       VAR BYTE    BANK0   SYSTEM      ' location for STATUS register
psave       VAR BYTE    BANK0   SYSTEM      ' location for PCLATH register
;----[ MIBAM Setup ]--------------------------------------------------------
BAM_COUNT CON 3                     ; How many BAM Pins are used?
INCLUDE "MIBAM.pbp"                 ; Mirror Image BAM module
RED    VAR BYTE
GREEN  VAR BYTE
BLUE   VAR BYTE
BAM_LIST  macro                     ; Define PIN's to use for BAM
     BAM_PIN (PORTB,0, GREEN)       ; Pin 6
     BAM_PIN (PORTB,1, BLUE)        ; Pin 7
     BAM_PIN (PORTB,2, RED)         ; Pin 8
  BAM_INIT  BAM_LIST                ; Initialize the Pins
;----[ Chip Setup ]--------------------------------------------------------
define osc 4
TRISA     = %00011111  ' Set PortA I/O
TRISB     = %11111000  ' Set PortB I/O
;----[ Adjustment Setup ]-------------------------------------------------
RED_VAL var byte
GREEN_VAL var byte
BLUE_VAL var byte
UP_SEL var bit
DN_SEL var bit
RED_PORT var PORTA.1        'Pin 18
GREEN_PORT var PORTA.0      'Pin 17
BLUE_PORT var PORTA.4       'Pin 3
UP_PORT var PORTA.2         'Pin 1
DN_PORT var PORTA.3         'Pin 2
;----[ Inital Settings ]--------------------------------------------------
RED_VAL = 0
GREEN_VAL = 0
BLUE_VAL = 0
;----[ Program ]----------------------------------------------------------
    gosub led
    gosub Adjust
Adjust:
    if PORTA = 0 then main
    Red_Up:
    if red_val > 250 then red_dn
    if red_port = 1 and up_port = 1 then
    red_val = red_val +1
    Red_Dn:
    if red_val = 0 then green_up
    if red_port = 1 and dn_port = 1 then
    red_val = red_val -1
    Green_Up:
    if green_val > 250 then green_dn
    if green_port = 1 and up_port = 1 then
    green_val = green_val +1
    Green_Dn:
    if green_val = 0 then blue_up
    if green_port = 1 and dn_port = 1 then
    green_val = green_val -1
    Blue_Up:
    if Blue_val > 250 then BLue_dn
    if Blue_port = 1 and up_port = 1 then
    Blue_val = Blue_val +1
    Blue_Dn:
    if Blue_val = 0 then main
    if BLue_port = 1 and dn_port = 1 then
    Blue_val = Blue_val -1
LED:
    red = red_val
    pause 20
    blue = blue_val
    pause 20
    green = green_val
    pause 20
