Problem
Results 1 to 7 of 7
Thread: Problem
    Default Problem
    PIC16F628A, RB4 does nothing, no matter what. Changed programs from simple to complex many times. Tried 3 different ICs and still nothing. All other ports work OK. What else could be wrong?
    high portb.4
    low portb.4
    Jan 2008
    Try to add this in the beginning of your program
    CMCON = 7
    And read the PBP manual page 10, 2.5.1
    If it still does´t work, check the config bits.
    It could be the LVP (Low Voltage Programming).
    Try adding ...
    @  DEVICE  LVP_OFF
    But then, that is a PBP default, so it should already be there.
    <br>
    Apr 2005
    Virginia
    StoneColdFuzzy,
    Could you post all your code up to your main routine? If we could see what intializations you've done, we might be able to better help. I assume you've set your TRISD register for pin 4 as an output. That leaves comparator pins, which Fredrick addressed, and possibly analog pins - sorry, I don't have the datasheet right in front of me. I'll also make the assumption that you've doubled-checked your wiring. That cost me a mistake for the longest time this week as Darrel can atest to.
    Quote Originally Posted by StoneColdFuzzy View Post
    PIC16F628A, RB4 does nothing, no matter what. What else could be wrong?
    Could be a breadboard problem, could be you have mistaken which pin is RB4 (I have done that), could be an inverted polarity LED you are using or a bad one or open resistor or other wiring error. Without seeing the breadboard and the exact code we are shooting in the dark.
    You'd think after 5 years of doing this I'd know to watch the config bits, One wrong click was all it took. It was in fact the LVP. Thanks for the replies!
    That was the whole main routine that I had last tried. I cut everything else out to work on the problem.
    Damn, I feel silly.
    ~ Dave
    Damn, I feel silly.
    ~ Dave
    We have all been there Dave.
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 20:52
  2. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 09:12
  3. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 22:04
  4. Hardware problem or what ?
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 22:39
  5. 1 slave 1 master 1 MAX232 1 problem ?
    By SuB-ZeRo in forum mel PIC BASIC Pro
    Last Post: - 31st July 2005, 23:59
