I'm using PIC 18F4550
You say that you may have found solution... Are you referring to the 18F4550.BAL? If so then the solution is not there, because I have that file in C:\PBP directory. If you are pointing to something else, please let me know what you are pointing at! Thank you anyway for trying to help me on this matter...
You can see the code that can be compiled without errors with PBP but not with PBPL...
...So, do you have any other suggestions, how to proceed from here...?
