PIC16f84A shiftout problem
Results 1 to 2 of 2
    Jan 2007
    Unhappy PIC16f84A shiftout problem
    Hi To all, I am having problem on pic16f84A's Shiftout function.
    i had tried some examples in our forums my problem is the clock pin is always high = 5V I checked the data pin it sends out data but the clock pin is always high I checked with my vom(voltmeter) after debugging i found out that the common of the two pins are different, I have plenty of PIC and replaced but still the same, can you help me pls. Thanks and more power.
    Jan 2007
    Unhappy Ps/2 interface correct schematic
    I would like to ask if someone has a correct and running schematic diagram connection from pic to PS/2 interface.
  1. Replies: 18
    Last Post: - 4th July 2017, 14:26
  2. 7 Segment Displays and MAX7219
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 31st October 2010, 18:30
  3. problem with Shiftout on RC6,RC7.
    By MOUNTAIN747 in forum Serial
    Last Post: - 5th January 2009, 00:35
  4. Smart Star (how to use shift registers)
    By mackrackit in forum Code Examples
    Last Post: - 30th November 2008, 20:06
  5. UP/down counter & shiftout interupt problem
    Last Post: - 2nd July 2007, 15:56
