Pic 12F509??
Results 1 to 7 of 7
Thread: Pic 12F509??
    Default Pic 12F509??
    Hello all i am a newbie here,
    well i have been given this schematic as a challenge (attached)
    i have no previous experience writing in program for pics
    my assignment was to write a program that would turn the motor on for 6 sec
    if the switch was pressed.
    how would i go about starting this?????
    Welcome.
    No experience at all...
    Lets start off by finding out what too;s you have to work with.
    Programmer?
    Pic Basic or Pic Basic Pro?
    Do you have MPLAB installed?
    We normally like to start folks off with an LED blinking program, but yours also looks like a good one to start with.
    One of the first things you need to understand is how to configure the PIC.
    This thread will help you there.
    And this is useful.
    http://www.picbasic.co.uk/forum/showthread.php?t=555
    The basic code for you app.
    LOOP:
    IF PORTx.x = 1 THEN   'Switch pin
    HIGH PORTy.y    'Motor pin
    PAUSE 6000
    LOW PORTy.y
    LOW PORTy.y
    GOTO LOOP
    Wink KISS method ...
    Hi, Northdelights
    First of all, Welcome here.
    I remember having built such a circuit 10 years ago ( goal was to power a soap pump for 3 secs ... more if finger kept on button ) with a single 555 timer as a monostable multivibrator.
    As the case is the same ... you can make the 555 look like a pic ...
    honour will be saved ...
    Welcome.
    Programmer?
    And this is useful.
    LOOP:
    PAUSE 6000
    LOW PORTy.y
    LOW PORTy.y
    GOTO LOOP
    Thank you dave for the advice and for also providing the code for me that was kind of you.
    Ill look into it alittle more to determine how you get there and how label each pin
    Hello northdlights,
    Welcome,
    Here are some links that are really going to be "assigned reading" because you absolutely need to know this. You would do well to avail yourself of all the links in the <b>FAQ</b> section available from the forum home page. Probably the most difficult thing to learn is how to interpret the data sheets
    http://www.picbasic.co.uk/forum/showthread.php?t=561
    When you go to the FAQ section you may need to set the Display Options at the bottom of the page to show threads from the beginning.
    Quote Originally Posted by Joe S. View Post
    Hello northdlights,
    Welcome,
    Hi joe
    thanks for the links,
    yeah i had gotten a start at the data sheet and it gets me lost i have to read it about two times to connect the dots
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. PIC 12F509 begins to heat at power up
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 25th July 2009, 12:11
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
    Last Post: - 11th March 2005, 23:14
