automated 4-stroke kill switch using PIC
Results 1 to 9 of 9
    Hi, Joe
    YES, the HV winding !!! which is a special winding in the "generator", just dedicated to produce the "400vDC" to charge the CDI capacitor ...
    Want to see ( and hear her roaring ... ) my Kawasaki KH500 tri-cylinder ???
    NO No I believe you, but are we to assume it is a late model motorcycle? I think we should do as we did and present all possibilities since we do not know what he is working on. BTW 400v is high voltage compared to 5v, compared to 30,000 volts I would call it primary voltage. Anyway what matters is that we are helpful to the OP. Oh BTW, nice bike!
    Jun 2008
    Smile Kill switch
    Thanks guys for all your info, every time i post a question you are always their with advice.
    In my opinion their must be a secondary winding inside the motor that would step down the voltage to 400vdc because every kill switch uses normal 16 gauge wire rated for 600v. I will just take a chance and measure it
    thanks alot guys here is the link i read that from ground to to the spark plug their is 30000 volts.
    http://www.jetav8r.com/Vision/Ignition/CDI.html
  1. Replies: 24
    Last Post: - 2nd October 2017, 12:35
  2. PIC10F200 Automated IR Light Switch
    Last Post: - 3rd May 2007, 12:40
  3. Replies: 2
    Last Post: - 10th June 2005, 03:34
  4. Serial Pic to Pic using HSER
  5. Battery Backup with PIC controlling switch
    By Dwayne in forum Schematics
    Last Post: - 27th December 2003, 14:16
