As said in post 1#, both (SCL and SDA) are pulled up with 2 2k2 resistors, one for each. So when the lines are inactive you can measure 4,98V there, so that suggest also that the problem has to be somewhere else. I have also looked with an oscilloscope on the active signals, but being not so familiar with the inner live of the I2C protocol, can't tell if there would be something wrong, to me they look "normal". From the clock line I could calculate a clock frequency of something around 65kHz +/-20%. Is that OK?
