Hello financecatalyst,
here is an example code setup for MPASM, you will have to comment out the config in your PBP 12F635.inc file to avoid overwriting . . . error.
'*  Name    : financecatalyst  .BAS                             *
'*  Notice  : Copyright (c) 2009 [select VIEW...EDITOR OPTIONS] *
'*  Date    : 1/14/2009                                         *
@ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF & _BOD_ON & _PWRTE_ON
PortA = %00000000
TrisA = %00000001
CMCON0.0 = 1           'These 3 statements disable analog comparators
CMCON0.1 = 1
CMCON0.2 = 1
VRCON.7 = 0            'This disables voltage reference for comparators
LOOP:
IF PortA.0 = 1 THEN    ' True or false check of port status
HIGH PortA.1           ' If true makes port status high
pause 3000             ' Here is your 3 seconds
ELSE                   ' Goes here if False
LOW PortA.1            ' And makes port status low
ENDIF                  ' Ends the T/F test
GOTO Loop              ' Starts the process over, forever
The config statement is where you enable / disable the Power up timer and Brown out detect etc. . .
