One EEPROM, 3 PIC's
Results 1 to 8 of 8
Threaded View
  1. #7
    Question
    Steve,
    Can you give a more detailed example of the BUSY line technique please?
    I am using a Master 16F628 with multiple Slave 16F628 using USART communication (HSERIN via TX/RX lines).
    I'd like to be able to use a BUSY line to indicate when the line is busy. At first thought I would think that HIGH = NOT BUSY and LOW = BUSY, that way there is no power signal at the same time as communication, less risk of disruption.
    NOTE: It is not known which Slave will be connected to the system. There might be none, or there might be several, that'S why I'm looking for a flexible way of Slaves to send data.
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. Multiple Pics accessing single EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 18:22
  4. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 20:42
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
