Memory use - how much do you use?
Results 1 to 17 of 17
    My code isn't really this, but I get similar results using this example:
    myvar1 var byte
    myvar2 var byte
    myvar3 var byte
    myvar4 var byte
    myvar5 var byte
    myvar6 var byte
    myvar7 var byte
    myvar8 var byte
    myvar9 var byte
    myvar10 var byte
    myvar11 var byte
    myvar12 var byte
    myvar13 var byte
    myvar14 var byte
    myvar15 var byte
    myvar16 var byte
    myvar17 var byte
    myvar18 var byte
    myvar19 var byte
    myvar20 var byte
    myvar21 var byte
    myvar22 var byte
    myvar23 var byte
    myvar24 var byte
    myvar25 var byte
    myvar26 var byte
    myvar27 var byte
    myvar28 var byte
    myvar29 var byte
    myvar30 var byte
    myvar31 var byte
    myvar32 var byte
    myvar33 var byte
    myvar34 var byte
    myvar35 var byte
    myvar36 var byte
    myvar37 var byte
    myvar38 var byte
    myvar39 var byte
    myvar40 var byte
    myvar41 var byte
    I admit this is more than 48.44 percent of the 64 bytes of SRAM. I am not clear how to check SRAM use in any other way than using your program. Perhaps PBP uses the other bytes for itself. But then, your program should account for actual use, since it is using the lst file.
    Let me know what you think.
    Walter
    http://www.scalerobotics.com
    I played with this some last night, did some reading and could not find a solution.
    Maybe Darrel or Bruce will chime in...
    DING!
    PBP's system vars use a minimum of 24 bytes.
    Complex formulas can increase that, but it appears you don't have any of those yet.
    So you create 40 additional byte variables and it's full. (24 + 40 = 64)
    As for "LST View" ...
    It apparently just looks for the last occurrence of "RAM_START +" and uses that address to calculate how much RAM was used.
    That address is already referenced to RAM_START, but in the program, this line subtracts the start address again, which leaves the count too low.
    ramU = ramF - ramS
    Add 20h (32) to the 31 bytes reported and you get 63, the last address in RAM.
    I think that line should be ...
        ramU = ramF + 1
    However, RAM assignments are not always contiguous. You could have a single variable in BANK3 (chip other than 675) and it'll show almost all the RAM has been used, when there's only a few bytes being used. Or the last address may be the beginning of an array, which it won't count either.
    It's a difficult task to count RAM bytes used.
    Thanks Darrel.
    I saw where LST View was giving some "funny" results last night also. Now I know why. Time to do a "bug" fix. If possible...
    Dave,
    Just a little more info for updating LST View.
    It calculates the Total RAM by taking (RAM_END - RAM_START + 1)
    As an example this is from a 16F877 ...
      00000020            00012 RAM_START                       EQU     00020h
      000001EF            00013 RAM_END                         EQU     001EFh
      00000004            00014 RAM_BANKS                       EQU     00004h
      00000020            00015 BANK0_START                     EQU     00020h
      0000007F            00016 BANK0_END                       EQU     0007Fh
      000000A0            00017 BANK1_START                     EQU     000A0h
      000000EF            00018 BANK1_END                       EQU     000EFh
      00000110            00019 BANK2_START                     EQU     00110h
      0000016F            00020 BANK2_END                       EQU     0016Fh
      00000190            00021 BANK3_START                     EQU     00190h
      000001EF            00022 BANK3_END                       EQU     001EFh
    (RAM_END - RAM_START + 1) = 1EFh - 20h + 1 = 464 bytes
    But the 16F877 only has 368 bytes.
    The extra count is from the SFR's that are at the top of each bank.
    GP RAM in each bank doesn't start at the same place on every 16F, so I think you'll need to find the amount in each bank and add them together to get the total RAM.
    (BANK0_END - BANK0_START + 1) + (BANK1_END - BANK1_START + 1) + (BANK2_END - BANK2_START + 1) + (BANK3_END - BANK3_START + 1)
    (  0007Fh  -   00020h    + 1) + (  000EFh  -   000A0h    + 1) + (  0016Fh  -   00110h    + 1) + (  001EFh  -   00190h    + 1)
    (            60h            ) + (            50h            ) + (            60h            ) + (            60h            )
    = 170h = 368
    Then it's the same for the Used RAM. You need to subtract the SFR space from the variables address, or somehow reference it to the BANKx_START of the bank that it's in to find out how much has been used.
    hth,
  1. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 01:22
  2. Replies: 4
    Last Post: - 2nd March 2007, 07:12
  3. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  4. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 19:38
  5. memory button
    Last Post: - 12th February 2006, 10:47
