Memory use - how much do you use?
Results 1 to 17 of 17
    Wink With MPLAB, now ...
    Thanks, Dave ... nice tool. ( heuuu .. could you just keep the last opened folder in the "open" window ??? )
    Another way in MPLAB ... the "Memory usage gauge" works with PBP !!!
    just open the "mem usage Gauge" and use " File \ Import \ Myfile.hex " in the menu ... the program "Camembert" ( understand : meter ) will work as it should ... but not the Data one ...
    Thanks.
    That is one of the things I will add on the next version (someday).
    BTW. Here is the source code, written in Liberty Basic.
    I will most likely use Python the next time.
    [setup.main.Window]
        '-----Begin code for #main
        nomainwin
        WindowWidth = 550
        WindowHeight = 225
        UpperLeftX=int((DisplayWidth-WindowWidth)/2)
        UpperLeftY=int((DisplayHeight-WindowHeight)/2)
        '-----Begin GUI objects code
        statictext #main.statictext1, "Code Path and Name",   5,  47, 155,  20
      '  TextboxColor$ = "white"
        textbox #main.name,   5,  67, 530,  25
        statictext #main.statictext3, "Program Memory",   5, 122, 120,  20
        statictext #main.statictext4, "Chip",  10,  17,  27,  20
        textbox #main.chip,  45,  17, 100,  25
        statictext #main.statictext6, "Free", 240, 102, 105,  20
        textbox #main.ByteWord, 130, 122, 50,  25
        textbox #main.FreeWord, 210, 122, 100,  25
        statictext #main.statictext8, " Used", 355, 102,  55,  20
        textbox #main.UsedWords, 325, 122, 100,  25
        statictext #main.statictext12, "Percent Used", 440, 102,  82,  20
        textbox #main.PercentWord, 435, 122, 100,  25
        button #main.btOPEN,"OPEN",[btOPEN], UL, 345,  17,  80,  25
        button #main.btREFRESH,"REFRESH",[btREFRESH], UL, 440,  17,  95,  25
        statictext #main.statictext16, "SRAM (BYTES)",  35, 152, 120,  20
     '   statictext #main.statictext15, "EEPROM (BYTES)",  30, 177, 140,  20
        textbox #main.ramF, 210, 152, 100,  25
     '   textbox #main.eepF, 210, 182, 100,  25
        textbox #main.ramU, 325, 152, 100,  25
     '   textbox #main.eepU, 325, 182, 100,  25
        textbox #main.ramP, 435, 152, 100,  25
     '   textbox #main.eepP, 435, 182, 100,  25
        statictext #main.txtWORKING, "WORKING", 185,  17,  85,  20
        statictext #main.txtFINISHED, "FINISHED", 185,  17,  75,  20
        '-----End GUI objects code
        open "LST VIEW" for window as #main
        print #main.UsedWords, "!font ms_sans_serif 10 bold"
        print #main, "font ms_sans_serif 10"
        print #main.statictext3, "!font ms_sans_serif 10 bold"
        print #main.statictext16, "!font ms_sans_serif 10 bold"
     '   print #main.statictext15, "!font ms_sans_serif 10 bold"
        print #main.txtWORKING, "!font ms_sans_serif 10 bold"
        print #main.txtFINISHED, "!font ms_sans_serif 10 bold"
        print #main, "trapclose [quit.main]"
        [main.inputLoop]   'wait here for input event
       ' print #handle.ext, "!hide"
        print #main.txtWORKING, "!hide"
        print #main.txtFINISHED, "!hide"
        wait
        [btOPEN]   'Perform action for the button named 'btOPEN'
        filedialog "OPEN ","C:\*.lst", openfile$
        if openfile$ = "" then wait
        [rFresh]
        open openfile$ for input as #Lfile
        print #main.name, openfile$
        print #main.txtWORKING, "!show"
        [LOOPcn]
        line input #Lfile, line$
        if mid$(line$,29,9)= "RAM_START" then RS$ = mid$(line$,68,6)
        if mid$(line$,29,7)= "RAM_END" then RE$ = mid$(line$,68,6)
        if mid$(line$,69,11)= "RAM_START +" then RFIN$ = mid$(line$,81,6)
       ' if mid$(line$,29,9)= "RAM_START" then #main.ramF,mid$(line$,68,6)
       ' if mid$(line$,29,7)= "RAM_END" then #main.ramU,mid$(line$,68,6)
        if mid$(line$,1,26)= "Program Memory Bytes Used:" then #main.UsedWords,mid$(line$,27,92)
        if mid$(line$,1,26)= "Program Memory Words Used:" then #main.UsedWords,mid$(line$,27,92)
        if mid$(line$,1,26)= "Program Memory Bytes Free:" then #main.FreeWord,mid$(line$,27,92)
        if mid$(line$,1,26)= "Program Memory Words Free:" then #main.FreeWord,mid$(line$,27,92)
        if mid$(line$,1,2)= "__" then #main.chip,mid$(line$,3,12)
        if eof(#Lfile) = -1 then [closeFILE1]
        goto [LOOPcn]
        [closeFILE1]
        close #Lfile
        [LOOPpm]
        if mid$(line$,1,26)= "Program Memory Bytes Used:" then #main.ByteWord,mid$(line$,16,5)
        if mid$(line$,1,26)= "Program Memory Words Used:" then #main.ByteWord,mid$(line$,16,5)
        if eof(#Lfile) = -1 then [closeFILE2]
        goto [LOOPpm]
        [closeFILE2]
        close #Lfile
        print #main.chip, "!contents? cName$"
        bFile$ = "C:\PBP\";(trim$(cName$));".bas"
      '  print #main.eepP,bFile$
       goto [closeFILE]
        wait
        [btREFRESH]   'Perform action for the button named 'btREFRESH'
        if openfile$ = "" then [rfERROR]'notice "SELECT FILE"
        goto [rFresh]
        wait
        [closeFILE]
      '  close #Lfile
        print #main.UsedWords,"!contents? UW"
        print #main.FreeWord,"!contents? FW"
        TW = UW + FW
        PW = (UW / TW) * 100
        print #main.PercentWord,using("###.##",PW)
        ramS = hexdec(RS$)
        ramE = hexdec(RE$)
        ramT = ramE - ramS + 1
        ramF = hexdec(RFIN$)
        ramU = ramF - ramS
        ramFree = ramT - ramU
        ramP = (ramU / ramT) * 100
        print #main.ramF,ramFree
        print #main.ramU,ramU
        print #main.ramP,using("###.##",ramP)
        print #main.txtFINISHED, "!show"
        wait
        [rfERROR]
        goto [main.inputLoop]
        wait
        [quit.main] 'End the program
        close #main
    Talking
    Hi, Dave
    You will laugh, but ...
    I decided long time ago to be ONLY a Computer USER !!! ...
    MUCH better for Health ... lol
    Hi, Dave
    Yep, got a chuckle hearing that from you
    I think sometimes I should decide as you did.
    I have some code that I have been working on for a PIC12F675. When I try to add another variable to it and then compile, I get - Error: Unable to fit variable y -. I am using the latest pbp, microcode studio, and mpasm v8.15. When I use Mackrackit's LST View program, it shows my successful compile (one less variable) as using about 70 percent of the code space, and 48 percent of the sram space. What would be stopping me from being able to use the other half of my sram? I looked in the 12F675.BAS file, and my memory map is BANK0 $0020, $005F, which is correct in the data sheet. 12F675 is selected in mcs.
    Confused....
    http://www.scalerobotics.com
    Can you post your code?
    My code isn't really this, but I get similar results using this example:
    myvar1 var byte
    myvar2 var byte
    myvar3 var byte
    myvar4 var byte
    myvar5 var byte
    myvar6 var byte
    myvar7 var byte
    myvar8 var byte
    myvar9 var byte
    myvar10 var byte
    myvar11 var byte
    myvar12 var byte
    myvar13 var byte
    myvar14 var byte
    myvar15 var byte
    myvar16 var byte
    myvar17 var byte
    myvar18 var byte
    myvar19 var byte
    myvar20 var byte
    myvar21 var byte
    myvar22 var byte
    myvar23 var byte
    myvar24 var byte
    myvar25 var byte
    myvar26 var byte
    myvar27 var byte
    myvar28 var byte
    myvar29 var byte
    myvar30 var byte
    myvar31 var byte
    myvar32 var byte
    myvar33 var byte
    myvar34 var byte
    myvar35 var byte
    myvar36 var byte
    myvar37 var byte
    myvar38 var byte
    myvar39 var byte
    myvar40 var byte
    myvar41 var byte
    I admit this is more than 48.44 percent of the 64 bytes of SRAM. I am not clear how to check SRAM use in any other way than using your program. Perhaps PBP uses the other bytes for itself. But then, your program should account for actual use, since it is using the lst file.
    Let me know what you think.
    Walter
  1. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  2. Replies: 4
    Last Post: - 2nd March 2007, 06:12
  3. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 02:37
  4. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 18:38
  5. memory button
    Last Post: - 12th February 2006, 09:47
