VFD and HPWM
Results 1 to 4 of 4
Thread: VFD and HPWM
    Dec 2004
    nebraska
    Default Hpwm
    Chip I am using is the 18LF6722, the data sheet says it has 3 ECCP pins. Using pbp 2.46 is it possible to run 3 seperate HPWM pins. I assume that the frequency has to be the same for all three, but that is ok.
    I read in a post that pbp 2.50 allows up to 4 HPWM channels but I can not found how many channels pbp 2.46 allows. I only need three so if pbp 2.46 allows three I do not want to buy pbp 2.5. I can't find a sales reciept although I think I bought pbp 2.46 directly from the melab site. If PBP 2.46 allows 3 HPWM channels I have yet to figure out how to access the third. Can someone help please.
    Sep 2005
    Campbell, CA
    The PBP HPWM command is very limiting, so I have never used it, although I use th HPWM features extensively.
    You can use all the channels your chip has by directly writing to the CCPx registers. *ANY* version of PBP will work.
    The part where most people get messed up is that you have to write bit 0 of the PWM value to CCPxCON.4 and bit 1 to CCPxCON5. The
    rest of the value (shift the value right two places) goes to CCPRxL.
    Charles Linquist
