ANSEL command
Results 1 to 5 of 5
Thread: ANSEL command
    Jan 2006
    Slovenia EU
    Default ANSEL command
    Hello,
    I was made one simple test program with ADC. I have problem with MCS compiled. I don't understand what is wrong with ANSEL = 1 command? Into status line write syntax error!! When disable this ANSEL command compiled finished ok. I was trying compile with PBP2.50b and MPASM and result is equal.
    Who is problem here?
    @ Device PIC12F675,WDT_ON,PWRT_ON,PROTECT_OFF,MCLR_OFF,BOD_ OFF
    ANSEL = 1
    ADCON0 = 3
    CMCON = 7
    DEFINE OSCALL_2K 1
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    w0 VAR WORD
    w1 VAR WORD
    w2 VAR WORD
    w3 VAR WORD
    w4 VAR WORD
    w5 VAR WORD
    w6 VAR WORD
    w7 VAR WORD
    out VAR GPIO.2
    meritev: ADCIN 0, w0
    w1= 1023-w0/2
    high out
    pause w1
    low out
    pause w1
    goto meritev
    Wink
    [ Humour ON ]
    You really sure to want the answer ???
    [ Humour OFF ]
    Now,
    DEFINE OSCALL_2K 1
    MUCH Better :
    DEFINE OSCCAL_1K 1
    ANSEL = 1
    ADCON0 = 3
    Much better
    ANSEL    = %01110001 ; RC - GPIO.0 ana.
    ADCON0 = %10000000 ; for 10 bits ... right justif !!! - wait for ADCIN to start.
    AND For the end ...
    You did not define the I/Os ...
    TRISIO = %11001001 ; if you want GPIO.0 to work as an ADC input. ( see manual ! )
    At this level ...
    You MIGHT open
    1) THE Manual
    2) The Pic relevant Datasheet ...
    Jan 2006
    Slovenia EU
    thanks Alain
    I was repair our routine and result is no unchanged. Here must be another problem
    show attachment
    Wink
    I do not think this:
    exist with PBP, PM, MPASM, nor MCS ...
    last effort ... go on !!!
    Jan 2006
    Slovenia EU
    Hello!
    I was repaired this problem.
    I was copy compiled file on location where have MCS and run it :
  1. My code for TV remote and MIBAM for RGB control
    By idtat in forum Code Examples
    Last Post: - 12th January 2013, 20:52
  2. Easy HID Command -Response application
    By ptig185 in forum USB
    Last Post: - 22nd September 2010, 19:56
  3. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 20:31
  4. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 18:57
  5. Interupts and Command string
    By Tissy in forum Serial
    Last Post: - 17th March 2006, 23:59
