100KHz pwm
Results 1 to 5 of 5
Thread: 100KHz pwm
    Feb 2004
    Michigan, USA
    Default 100KHz pwm
    Hi folks, not visited the site in a while. I see this place is much more livelier!
    I'm still using old skool v2.43 and 18F1320's. I need a 100KHz pwm, but the data sheet is saying max is 30 something KHz.
    How can I get a 100KHz pwm out of a 1320, or if I cannot, what is a decent replacement part these days?
    PBP's HPWM command is limited to 32767 Hz, but you can easily get 100khz (and much higher) from the CCP module.
    You just need to set the registers manually.
    Feb 2004
    Michigan, USA
    Not sure how to use the ccp yet - never needed to use it so far.
    Is there a ccp tutorial with pbp sample code anywhere? A quick search dosent reveil too much.
    Heads off to locate the manual.
    Bruce has a good explanation here.
    It's for 38khz, but you just change the numbers for higher freqs. ...
    Using The PIC Microcontroller Hardware PWM Feature & Infrared Communications
    http://www.rentron.com/Infrared_Communication.htm
    And for easy PWM calculations ...<br>
    Sep 2005
    Campbell, CA
    If you look at the "special use" label about 3/4 of the way down in this program, you can see how it is done.
    http://www.picbasic.co.uk/forum/show...onitor+program
    Charles Linquist
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM 'channels ...what's that all about then!
    By HankMcSpank in forum General
    Last Post: - 23rd April 2009, 17:49
  4. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
