Variable within Variable
Results 1 to 6 of 6
    Nov 2008
    Default Variable within Variable
    I would like to use a variable within a variable ie instead of:
    If Data_Sen1 = 255 then
    I would like to use:
    If Data_Sen(Current_Sensor) = 255 then
    Where Current_Sensor is a variable from 1 to 3
    Can't seem to find anything on this, but thought I had at one time ....
    Mark
    You mean an ARRAY variable?
    Section 4.5 Page 23 of your PBP manual.
    Nov 2008
    I think an array may work, I'm playing with it now.
    To answer your question mark at the end of the message, essentially I have three sensors which need calibration and one button used to do the calibration. The three sensors calibration values are stored in variables (Data_Sen1, Data_Sen2, Data_Sen3). I wanted to write the code so it "loops" and which sensor you're calibrating is changed with a certian button push. I didn't want to write extra code for each sensor when I could do it in a loop.
    The calibration flow is as follows:
    -Enter the calibration loop
    system ready to cal sensor 1 (Data_Sen1)
    cal direction set to up (increase value)
    -if you push the button once, cal value increases by one.
    -if you push the button twice, cal direction switches to down (decrease value)
    -subsequent single button pushes decrease the cal value.
    -if you push the button three times, the program moves onto the next sensor (Data_Sen2).
    -push the button four times and we exit the calibration loop.
    It looks like I could use sensor variables in an array such as Data_Sen[i] and alter the value of i as I move through the program.
    I'm pretty sure I've used this before and just forgot, thanks for the reminder. I also recall that setting up an array such as:
    Data_Sen var byte[3] would give Data_Sen[0] thru Data_Sen[2]. I'd need to setup Data_Sen var byte[4] if I wanted to use the numbers [1] -> [3]
    Mark
    Remember counting starts at ZERO... so...
    Data_Sen var BYTE [3]
    ...gives you three elements...
    Data_Sen(0)
    Data_Sen(1)
    Data_Sen(2)
    Oh... Note the use of round ( ) brackets above? Although it doesn't say it in the manual, you can use them as easilly as you can square ones [ ] too.
    Nov 2008
    Thanks all, works like a champ. I knew I'd done this before, but apparently I'd forgotten. It all came back once I got back on the bike. I just needed a push start.
    Thanks again,
    Mark
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 01:06
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. WORD vs BYTE variable lengths
    By bartman in forum General
    Last Post: - 28th November 2005, 22:16
  5. Storing a variable in EEPROM
    Last Post: - 29th October 2005, 14:53
