Can someone please help me i am trying to get a boot loader working(first timer) i use the microchip loader for the 18F4550 over USB
The problem is that everything works the first time but when i open my hex file the loader comes up with a message that the config differs from the board, if i choose to use the board everything keeps on working but when i use the config from the hx file it seems to overite something in the bootloader code. after the chip resets the program works but i can't go back into bootloader mode. here is my code anyone got any ideas?
Code:INCLUDE "MODEDEFS.BAS" DEFINE LOADER_USED 1 DEFINE RESET_ORG 1000h ' For Microchip USB Bootloader DEFINE OSC 20 ' Define crystal as 20Mhz 'Define ACDIN parameters Define ADC_BITS 10 ' Set number of bits in result DEFINE ADC_CLOCK 3 ' Set clock source ( 3 = RC ) DEFINE ADC_SAMPLEUS 50 ' Set sampling time to micro-seconds 'This Part set PORTA 0-3 an analog inputs,4 as digital TRISA = %00011111 'set PORTA 0-5 as inputs ADCON1 = %00001010 'ADC use vss and vdd as ref. ADCON2 = %10000111 'FRC (clock derived from A/D RC oscillator),Right justify output TRISC = %10000000 TRISD = %00001111 'Set port d 0-3 as inputs and 4-7 as outputs TRISB = %10011000 '**************************************Serial port setup************************************* '*Serial port Setup 9600 8N1* DEFINE HSER_BAUD 9600 ; 9600 Baud DEFINE HSER_RCSTA 90h ' Enable serial port & continuous receive DEFINE HSER_TXSTA 24h ' Enable transmit, BRGH = 1 DEFINE HSER_CLROERR 1 ; Clear overflow automatically DEFINE HSER_SPBRG 129 '**************************************Variables********************************************* buffer Var Byte[16] cnt Var Byte LED Var PORTD.4 USBInit Low LED ' LED off '**************************************Main Program****************************************** idleloop: PORTD.7 = 1 PAUSE 1000 PORTD.7 = 0 PAUSE 1000 Goto idleloop ' Wait for next buffer END
