I started this project a couple of years ago and I was stuck when I put it to the side. I recently brought it back to life and I am still stuck!
Here is the deal: 16F628 w/20mHz OSC sends a "1 2 3 4" with a second between each character cycling over and over while bllinking an LED. The 628 sends the data to a 16F876 w/20mHz OSC on PortC.7 through an interrupt while going through an endless loop.
The problem: The 628 sends the varible "I" which equals (ASCII 1, ASCII 2, ASCII 3, or ASCII 4), but the 876 spits out 103 for the ASCII 1, a 51 for the ASCII 2, a 102 for the ASCII 3, and 25 for a ASCII 4. My Question is why?
Code for the 16F628
and the code for the 16F876Code:@ DEVICE HS_OSC,MCLR_OFF,LVP_OFF,WDT_OFF,PROTECT_OFF define OSC 20 CMCON = %00000111 ' Page 56, Comparators Off CHAROUT VAR PORTB.3 LED VAR PORTB.7 BAUD CON 6 I VAR BYTE PAUSE 2000 start: for I = 1 to 4 HIGH LED PAUSE 500 LOW LED PAUSE 500 SEROUT2 CHAROUT,16468,[#I] ' N9600 NEXT GOTO START
Code:@ DEVICE HS_OSC,LVP_OFF,WDT_OFF,PROTECT_OFF define OSC 20 INTCON = %01000000 ' Page 22, PEIE=1 PIE1 = %00100000 ' Page 23, RCIE=1 TXSTA = %00100100 ' Page 97, TXEN=1, BRGH=1 RCSTA = %10010000 ' Page 98 , SPEN=1, CREN=1 SPBRG=129 ' Page 100, 9600 BAUD (BRGH = 1) TRISC = %10000000 ' PortC.7 Input RCIF VAR PIR1.5 ' Page 24, USART Receive Interrupt Flag bit CHAR VAR BYTE X VAR BYTE FLAG VAR BYTE BAUD CON 6 ' 9600 Driven Inverted LCD VAR PORTC.4 on interrupt goto ROUTINE PAUSE 1000 ' Wait for LCD SEROUT LCD,BAUD,[12,"Working. . ."] '12=Clear screen and verify working PAUSE 1000 SEROUT LCD,BAUD,[12] '12=Clear screen loop: GOTO loop disable INTERRUPT ROUTINE: RCSTA=%00000000 ' Page 98, Serial port disabled, Disable continuous receive CHAR = RCREG ' Get character while RCIF ' Empty RCIF X = RCREG wend SEROUT LCD,BAUD,[12,#CHAR] ' Clear Sceen and display ascii value RCSTA=%10010000 ' Page 98 , SPEN=1, CREN=1 resume enable INTERRUPT
