Trying to make code smaller
Results 1 to 10 of 10
    Nov 2007
    Default Trying to make code smaller
    I am trying to shrink my code down but I am still "learning". Here is a example of what I am attempting to do.
    Say I use
    HIGH LED : PAUSEUS 50000 : LOW LED : PAUSEUS 50000
    Now if I wanted to multiply that by 10 to make the LED flash 10 times, I don't not want to have to write that line 10 times.
    Any help?
    May 2008
    Italy
    Led var portX.x
    A0 var Byte
    Loop:
    For A0 = 1 to 10
    Toggle Led
    Pause 50000
    next A0
    'comment the 3 lines hereunder for only ten flashes (leave the END)
    Low Led
    Pause 5000
    goto Loop
    This Example will flash led ten times. Led will turn off for 5 secs and flashing will repeat.
    Hope it is what you need.
    Happy new year
    Al.
    Nov 2007
    Quote Originally Posted by aratti View Post
    Led var portX.x
    A0 var Byte
    Loop:
    For A0 = 1 to 10
    Toggle Led
    Pause 50000
    next A0
    Low Led
    Pause 5000
    goto Loop
    Happy new year
    Al.
    when I write
    If button1 = 0 then test
    test:
    for a0 = 1 to 10
    toggle led
    pauseus 50000
    next a0
    low led
    pauseus 50000
    What happens is the led only flashes 4 times. I am using a 12F683 @ 8mhz OSC
    May 2008
    Italy
    Have you declared the variable A0? (A0 var byte)
    Have you defined the oscillator value? (DEFINE OSC 8)
    Have you declared to which pin the name "Led" belongs? (Led var PortX.x)
    Have you declared the pin to be an output? (Tris)
    Have you declared to which pin the name "button1" belongs? (button1 var PortX.y)
    Have you declared the pin to be an input? (Tris)
    Al.
    Nov 2007
    Have you declared the variable A0 (A0 var byte)?
    Al.
    yes, in the initialization
    I've used this method. I used FINISHED instead of END just in case you want to add a line that begins the cycle over again with an input switch.
    X VAR BYTE
    CLEAR
    START:
    HIGH LED : PAUSEUS 50000 : LOW LED : PAUSEUS 50000 : LET X = (X + 1)
    IF X < 10 THEN START
    FINISHED:
    'IF PORTA.0 = 1 THEN CLEAR : GOTO START
    GOTO FINISHED
    Nov 2007
    Quote Originally Posted by peterdeco1 View Post
    X VAR BYTE
    CLEAR
    START:
    FINISHED:
    GOTO FINISHED
    It only flashes once when the button is pressed. I want to get it so that when I press it the first time, it flashes the led once, press it again, and it flashes the LED twice, and so on.
    My initalization is this
    DEFINE OSC 8
    OPTION_REG = %0000000
    ANSEL = 0
    ADCON0 = 0
    CMCON0 = 7
    TRISIO = %00111011
    WPU = %00011010
    A0 var byte
    X var byte
    button1 var gpio.1
    led var gpio.2
    I am not at my bench to test this but it should work. Also, your pauseus 50000 is very fast. Try using pause 1000 to space the flashes at 1 second intervals.
    X var byte
    y var byte
    clear 'reset both to 0
    start:
    If button1 = 1 then start 'wait for button push
    let x = (x + 1) 'count button presses
    flashled:
    High led : Pauseus 50000 : Low led : Pauseus 50000 : Let y = (y + 1) 'count led flashes
    if y < x then flashled 'flash the led same number as button pushes
    if x >= 10 then clear 'reset both counters after 10 button pushes & flashes
    goto start
    May 2008
    Italy
    I don't know if the setting are correct since I have never used this chip.
    But assuming setting OK then this code will work as you want;
    Loop:
    If button1=0 then
    X=X+1
    goto Start
    goto Loop
    start:
    For A0 = 0 to X
    Toggle Led
    Pause 50000
    next A0
    if X=255 then X=254
    goto Loop
    Flashing will increment by one at every press upto 255.
    Now, you add a second button and relative code for decrementing the variable X.
    Al.
    When you are using Toggle command in an indexed loop you must double your index to get a certain number of blinks.
    In your case the index variable A0 should be 20. You also need to know what the status of your LED output is for a good control over the number of blinks and add or eliminate unnecessary pauses.
    Hope this helps.
    Nick
  1. Code doesn't work on 16F648A
    By Mr_Joe in forum mel PIC BASIC Pro
    Last Post: - 1st September 2018, 22:09
  2. I2C Master/Slave 16F88/16F767 working code
  3. Can someone help me make a code for this:
    By joseph in forum mel PIC BASIC
    Last Post: - 29th April 2009, 18:58
  4. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  5. Making Program Code Space your playground...
