problem with Shiftout on RC6,RC7.
Results 1 to 3 of 3
    Alabama,USA
    Default problem with Shiftout on RC6,RC7.
    I have been working with the LAB-X1 board using 877A to drive Sure Electronics 4” 5x7 dot matrix display. Display works fine with Shiftout on RC3,RC4 in mode 4 but I would like to use those pins for I2C. I use the same code with CLK VAR PortC6 and DATA VAR portC7 and the display fails. The X1 has 4.7k pull-ups on RC3-4 and I have used RC6-7 with and without pull-ups and still no display. Sure uses a clock idle high and LSBfirst. Shiftout mode 4 works fine in RC3-4. I have tried TRISC=%00000000 with no change in results. I can see no reason why RC6-7 would not work on Shiftout??? Comments please!
    Are you removing the MAX232 from the LAB-X1?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Alabama,USA
    Bingo! Thanks Bruce! I can't believe I overlooked that one.
  1. 7 Segment Displays and MAX7219
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 31st October 2010, 18:30
  2. PIC16f84A shiftout problem
    By naidab in forum mel PIC BASIC
    Last Post: - 14th January 2009, 00:06
  3. Smart Star (how to use shift registers)
    By mackrackit in forum Code Examples
    Last Post: - 30th November 2008, 20:06
  4. UP/down counter & shiftout interupt problem
    Last Post: - 2nd July 2007, 15:56
  5. Shorter Subroutines for MAX7219
    By exelanoz in forum mel PIC BASIC Pro
    Last Post: - 16th March 2007, 11:35
