Microcode studio - PIC16F877A Interrupts
Results 1 to 2 of 2
    Dec 2008
    Charlottesville, VA
    Post Microcode studio - PIC16F877A Interrupts
    Hello. I am trying to learn how to use the timer interrupts on the PIC16F877A. I have never used the timer registers before so I may be doing something wrong. I've searched the internet trying to find examples to go by and I've come up with a small program. It compiles in my software but when it is programmed to the PIC it won't display my variables on the LCD. Here is the code that I have so far:
    DEFINE OSC 20 ' Define 20MHz Oscillator
    DEFINE LCD_DREG PORTB ' Set LCD Data port
    DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 3 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 2 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2000 ' Set command delay time in us
    DEFINE LCD_DATAUS 50 ' Set data delay time in us
    PAUSE 1000 ' Pause for one second for power stabilization
    mS VAR WORD
    S VAR WORD
    Timer1 VAR WORD
    SYMBOL GIE = INTCON.7 'Global Interrupt Enable bit
    SYMBOL TMR1_Val = 65535 'Set the initial value of TMR1
    SYMBOL TMR1_mS = 1 'Time period of TMR1
    SYMBOL TMR1_Enable = PIE1.0 'TMR1 interrup enable
    SYMBOL TMR1_Overflow = PIR1.0 'TMR1 overflow flag
    ON INTERRUPT GOTO INTERRUPT_HANDLER 'Goto handler on interrupt
    DISABLE INTERRUPT
    MAIN:
    GOTO INITIALIZE
    REPEAT
    UNTIL S = 60
    S = 0
    INTCON = $80 'Permanently disables interrupts until called again
    GOTO MAIN 'Loop forever
    ENABLE INTERRUPT
    INITIALIZE:
    'TMR1 Interrupt Operation
    GIE = 0
    TMR1_Enable = 0 'Disables TMR1 Interrupt
    INTCON.6 = 1 'Peripheral Interrupts
    T1CON.1 = 0 '1 = External clock input from pin RC0
    '0 = Internal clock (FOSC/4)
    'TRISC.0 = 1 'If external clock, set clock as an input
    'HPWM 1, 128, 32000 'Set TMR1's external source
    T1CON.2 = 1 '1 = Do not synchronize external clock input
    '0 = Synchronize external clock input
    T1CON.4 = 0 '11 = 1:8 Prescale value
    T1CON.5 = 0 '10 = 1:4 Prescale value
    '01 = 1:2 Prescale value
    '00 = 1:1 Prescale value
    'When T1CON.1 = 0 this bit is ignored.
    'TMR1 uses the internal clock when TMR1CS = 0.
    Timer1 = TMR1_Val '
    TMR1_Enable = 1 '
    T1CON.0 = 1 '
    DISABLE INTERRUPT 'Disables interrupts in handler
    INTERRUPT_HANDLER:
    GIE = 0 'Disable Global interrupts
    IF (TMR1_Overflow = 1 && TMR1_Enable = 1) THEN
    TMR1_Enable = 0
    Timer1 = Timer1 + TMR1_Val
    Timer1.LowByte = TMR1L
    Timer1.HighByte = TMR1H
    TMR1_Enable = 1
    TMR1_Overflow = 0
    ms = ms + TMR1_mS
    IF (mS >= 1000) THEN
    mS = mS - 1000
    S = S + 1
    LCDOUT $FE, 1 ' Clear display
    LCDOUT $FE, 2 ' Return home (beginning of first line)
    LCDOUT $FE, $0C ' Cursor Off
    LCDOUT " ", DEC S, " S ", DEC mS, " mS" ' display elapsed time
    RESUME 'Return to main program
    ENABLE INTERRUPT 'Enable interrupts after handler
    Anyone that could help me out with this I would greatly appreciate it. Thank you all in advance.
    Aug 2008
    Your timer interrupt won't work if you disable global interrupt. Try changing to the below code to see if something is displayed first:
    DISABLE INTERRUPT
    GOTO INITIALIZE
    ENABLE INTERRUPT
    MAIN:
  1. 16F877A Microcode Studio won't compile
    By curt66111 in forum mel PIC BASIC Pro
    Last Post: - 25th November 2009, 20:35
  2. Help setting up MPASM with MicroCode studio
    Last Post: - 23rd November 2008, 06:12
  3. Microcode studio loader problem
    By woodygjw in forum General
    Last Post: - 10th September 2007, 02:18
  4. Microcode studio and USB pics
    By KPDes in forum mel PIC BASIC Pro
    Last Post: - 27th May 2007, 10:28
  5. How to used ICD of microcode studio
    Last Post: - 19th November 2005, 01:29
