mcs prob
Results 1 to 6 of 6
Thread: mcs prob
    Jun 2006
    Default mcs prob
    hi
    I'm not new to pics but have a problem
    i got new PC when i installed mcs pbp and tried to compile a simple program i get error (source file read only.msg) i have all original software
    for any asistance i would be for ever greatfull
    andrew
    New PC...
    Maybe you moved the file you are working on from the old PC via CD?
    Go to the directory where the file is located and check the properties, un-check the read only box.
    Jun 2006
    Default mcs prob
    the program i am trying to compile is one i created new simpily
    start:
    high 5
    pause 200
    low 5
    goto start
    it use to work but now i cant get it to work
    i can save as project but not compile
    thanks again
    from andrew
    Is
    all that it says?
    Any other clues?
    Jun 2006
    Default mcs prob
    the only mesage i get is source file read only
    i am running the same setup on another computer set up the same way runs fine
    thanks andrew
    ps i know i could use other pc but not the point should work on this pc same os same software
    Jun 2006
    Default mcs prob
    i have fixed problem i just included include 16f84a and it now compiles thanks for all your help
    andrew
  1. WRITE prob during power cycle 18f6722
    By jason in forum mel PIC BASIC Pro
    Last Post: - 24th May 2010, 23:06
  2. MCS error
    Last Post: - 4th December 2009, 03:54
  3. ICD use with MCS Plus, PBPro & PicKit2??
    Last Post: - 1st October 2009, 00:06
  4. MCS compiler error
    Last Post: - 13th November 2008, 03:35
  5. Help MCS with PICKIT2 programmer question
    By luminas in forum mel PIC BASIC Pro
    Last Post: - 1st February 2008, 18:57
