Hi To all, I am having problem on pic16f84A's Shiftout function.
i had tried some examples in our forums my problem is the clock pin is always high = 5V I checked the data pin it sends out data but the clock pin is always high I checked with my vom(voltmeter) after debugging i found out that the common of the two pins are different, I have plenty of PIC and replaced but still the same, can you help me pls. Thanks and more power.
